10-24-2010, 10:53 PM | #1 |
Nova sub frame posable issues
I have a 1950 chevy panel truck and was wondering what kind of issues i might run into going this way. I have aces to a 73 nova subframe. Some people say that they have problems with track width. And if anyone has done a rack and pinion swap. Did a search and found minimal information and not a lot of pictures.
10-25-2010, 12:07 AM | #2 |
Re: Nova sub frame posable issues
73 Nova is rear steer, problems with hooking up steering box to column, track width is about 60" , what is the track on 50 panel ?
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ |
10-25-2010, 07:41 AM | #3 |
I have a 74 nova on my 53, I bought 15x6 with a 4 inch backspacing wheel for the front
10-25-2010, 01:23 PM | #4 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=427246 Ray |
10-26-2010, 03:03 AM | #5 |
A320 Pilot/USAF Retired
I pretty sure the 73 Nova sub is a Front Steer, just like the Camaro.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
10-26-2010, 06:09 AM | #6 |
I think the 73 Nova is a rear steer,my 74 is. It wasn't that hard to put steering connections in,I don't no if I could run headers though. I had a motor in for mockup and I was using stock exhaust manifolds
10-26-2010, 10:05 AM | #7 |
75 and up is front steer same as 70-81 camaro, 68-74 is rear steer same as 67-69 camaro
10-26-2010, 03:53 PM | #8 |
Headaches are cheep to create, and expensive to cure
10-26-2010, 10:54 PM | #9 |
Thanks the sub frame is for sure a front steer unit which means it is a 74 i think. I like that last pearl of wisdom. I will have the sub frame tomorrow and can't waite to get started on this beast.
10-27-2010, 07:35 AM | #10 |
My bad! I thought the Nova was the same as the Camaro. Live and Learn!
Thanks!
10-27-2010, 12:38 PM | #11 |
Well some Novas are the same as some Camaros, so you have to say what years. Specifically, 68-74 Novas are the same as 67-69 Camaros and 75-79 Novas are the same as 70-81 Camaros.
Ray |
10-27-2010, 12:44 PM | #12 |
Not at all, ChuckDriver. Nobody knows everything, I just happen to know about Camaro's (and consequently Nova's) because I owned and built a ton of them before I got back into trucks. Here's a pic of one of the last ones I did around 7 or 8 years ago (crappy pic scanned from a photo)...
10-27-2010, 08:36 PM | #13 |
Nice camaro what was the power plant in that bad boy
10-27-2010, 10:16 PM | #14 |
That one was a mild 327 made to look externally stock. Car was basically a resto except for the steel cowl hood, SS emblem and corvette ralley's.
So did you pick up your Nova clip? Do you have any pics of your project?
10-28-2010, 11:09 PM | #15 |
I am getting the clip this weekend and probably will start a build thread. I haven't took too many pix yet
10-28-2010, 11:12 PM | #16 |
Here is a pix after we loaded it on the trailer. Hopefully it works
10-29-2010, 02:23 AM | #17 |
Cool bumper, saw one like that on a tow truck once.
11-01-2010, 01:54 PM | #18 |
Here are a couple of pictures of the 1975 nova subframe that i used on my 54 gmc. I have a bunch of pictures of the install if you need them. 75 is a front steer unit.
11-01-2010, 01:57 PM | #19 |
After the install...
11-01-2010, 02:03 PM | #20 |
This is the ride height without drop spindles (just stock nova suspension) with stock dodge charger 17" wheels and tires on it for mock up. this is completly maxed without coil springs.
11-01-2010, 02:40 PM | #21 |
Do you still have the stock bump stops in there?
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
11-01-2010, 10:19 PM | #22 |
No. i switched them out for a smaller size. about 1/2 inch tall. i plan on putting airbags on the front so hopefully the only time ill need bumpstops is when its air out sitting.
11-02-2010, 08:48 PM | #23 |
I would love to see more pix of your install. The new charger wheels are the same bolt pattern?
11-03-2010, 01:07 AM | #24 |
No charger wheel hole pattern are a little bit bigger, but they work for mock up and i had them in the garage. ill try and put some picts. up for you. This is where i started. cut the original frame and the new nova frame just behind the bottom horns where the lower a-arms attach. as you can see the original frame is a little bit skinnier than the nova sub frame. so i addapted it. then used construction paper to mock up my steel plate. you will also noticed i connected both side of the frames together with 3, 1/2" grade 8 bolts. just for back up in case any of the welds fail, the frame should hold together.
11-03-2010, 01:13 AM | #25 |
picts.
