10-25-2010, 12:38 AM | #1 |
Replace headers with stock manifolds and a carb question
Hi guys. Mechanic says I have some exhaust leaks, and says headers need to be redone...(I guess gaskets and bolts).
I want to learn to tackle some of the issues that I need to in order to get this old girl running correctly. Is this something a novice DIY'er could do? The truck is more of a "hot rod" than I would like, and was thinking going back to a stock manifold might cause me less headaches and get the truck back to stock like I would eventually like it to be. Any thoughts? Also....I don't know if it is a 454 or a 402. I did notice one header bolt is completely missing. Would this be enough to cause an easily detectable leak? Mechanic says carb is the wrong size for the engine. It is an Edelbrock Performer 800 CFM. Is this carb too much? Is it worth anything used (less than 1 year old)? Would you go back to a stock carb or stick with a 'lower' specd aftermarket one? Thanks for your support guys....I'm trying to learn. Randy |
10-25-2010, 01:14 AM | #2 |
Re: Replace headers with stock manifolds and a carb question
Headers are mostly a show and have exhaustly leaks frequently, there should be some casting numbers on the rear of the block, looks these up on line and it should tell you what your running. As for the eddy carb make a trade for the stock carb or sell it or maybe it would run better if it had the metering rods changed in it, above all else don't take just one persons advice, test the waters.
"gotta love something that works without a computer" |
10-25-2010, 02:07 AM | #3 |
Thanks for the reply. Will look into a stock exhaust manifold. Don't want to be constantly fussing with headers, and don't need a hot-rod. Want a stock truck.
