10-25-2010, 01:37 AM | #1 |
wheelbase
ok what is the wheel base for a 55/59 with a 9 foot step side box ?
short 114 long 123.25 extra long ??? thanks Last edited by DG Racing; 12-03-2010 at 01:50 PM. |
10-25-2010, 01:15 PM | #2 |
Re: wheelbase
The 9 foot box would be a 3800 series only and the WB on that is 135".
Ray |
10-25-2010, 02:23 PM | #3 |
Re: wheelbase
ok thanks
that is the box that i have but my 3600 is 125wb so i think i will cut to box to be a short box and cut the frame to have 114 wb . |
10-25-2010, 06:43 PM | #4 |
Re: wheelbase
Well post pics on your progress I was thinking of doing the same,I thought the actual step's were longer allso ?
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
10-25-2010, 07:57 PM | #5 | |
Re: wheelbase
Ray |
10-26-2010, 12:21 AM | #6 |
Re: wheelbase
ok when i baught my truck (dump bed ) i baught a long box from a friend of the seller and the seller ship me the truck and bed on the top of my dump truck ,
but when i received it from reno nevada i notice that it was not the long box that i whanted it was a very long box that it doesn fit in my wheelbase of 125 inch ( 3600 ). to instal that box i need to cut it to a standard long box .125 wb but if i need to cut that one so maybe i will cut it to a short box but yes i will have to cut the frame also . but yes if i can sell it back to buy a nice short box well that will be good for me |
11-20-2010, 12:48 AM | #7 |
Re: wheelbase
i just find that in 1957 it had 2 size of long bed
89 and 97 inchs so are they on the same 123.25 wheelbase ??? MAR-K Some information about 1957 Chevy models...A stepside bed has fenders attached outside the metal bed sides and a step extending from the rear fender to the back of the cab. Short Stepside: Length of bed wood 77 1/8". Inside width of bed 50”. Cameo: Has the same size inner bed as a short stepside, but has fiberglass outer bed side panels attached which makes the truck look like a later model fleetside truck. Tailgate is also different than a stepside or fleetside. Length of bed wood 77 1/8". Long Stepside 89": Length of bed wood 89”. Inside width of bed 50”. Long Stepside 97": Length of bed wood 97”. Inside width of bed 50”. 1 Ton Stepside: Length of bed wood 107 1/4”. Inside width of bed 50”. http://www.mar-k.com/catalog/index.aspx?VehCode=NEW |
11-20-2010, 01:30 AM | #8 |
Hollister Road Co.
Re: wheelbase
6.5 ft bed is 114" wheel base
8 ft bed is 123.25" wheel base 3100 is 114" WB 3200 is 123.25" WB 3600 is 123.25" WB 3800 is 135" WB and had a 9 ft bed box demensions can be found here toward the bottom http://www.thehollisterroadcompany.c...ck%20Data.html Last edited by dwcsr; 11-20-2010 at 01:32 AM. |
11-20-2010, 01:39 AM | #9 |
Re: wheelbase
ok but what is the wheel base on the Long Stepside 89": Length of bed wood 89”. Inside width of bed 50”.
this is not the 8 feet box its the 89 inch ?? |
11-20-2010, 03:00 AM | #10 |
Hollister Road Co.
Re: wheelbase
There is no 89 inch box.
Measure your box inside and tell me what you have. Front panel to tailgate along the side panel. Its either a 6.5', 8', or a 9' 6.5' (78-1/8") on a 114" wheel base 1/2 ton only 8' (98") on a 123.25" wheel base 1/2 ton long bed or 3/4 ton 9' (108") on a 135" wheel base 1 ton only |
11-20-2010, 12:28 PM | #11 |
Re: wheelbase
ok but why do they sale 89 inch wood for a 1955/56/57 ????
from mark-.com |
11-20-2010, 02:47 PM | #12 |
Hollister Road Co.
Re: wheelbase
Thats the length of the wood not the bed
11-20-2010, 05:31 PM | #13 |
Re: wheelbase
i know it the length of the wood but WHY they sale 4 DIFERENTE size of WOOD
stepside or fleetside. Length of bed wood 77 1/8". Long Stepside 89": Length of bed wood 89”. Long Stepside 97": Length of bed wood 97”. 1 Ton Stepside: Length of bed wood 107 1/4”. The box that i have doesnt fit my 125 wb truck i have a 9 foot box so i whant to buy another one or cut the one i have . but i still what to learn about those box because in 1955/56/57 it supossed to be 89 inch for the wood and 1958/59 its 97 inch ?? So a have a wheel base of 125 on my 1957 3600 truck so what size of bed that i need for my truck (i dont whant to buy the wrong one again so i need the exact specs .. Is their guys that have a Long box with 89 inch wood ??? or everybody as the 97 inch wood ??? thanks |
11-20-2010, 05:39 PM | #14 |
Hollister Road Co.
Re: wheelbase
I would call Mar-K and ask them about the wood
what is the vin number on your truck? |
11-20-2010, 05:48 PM | #15 |
Re: wheelbase
i will give them a call monday
my vin Starts with 3E57O11.... |
11-20-2010, 06:05 PM | #16 |
Re: wheelbase
Im going to check how difficult it is to cut my 9 foot box to a 89 ou 97 wood box to fit my 125 wheelbase .
or i do a major cut on my 9 foot box to do a short box with it , and cut the frame to 114 wb . i start to like this style (for sure my truck will be flat black ) it will be to tow my Fiat that will be Flat black next week also |
11-20-2010, 06:13 PM | #17 |
Hollister Road Co.
Re: wheelbase
Thats a 57-3600 with 123.25" wheel base and would have an 8ft bed.
I see what you mean about the two long beds for 57. Not sure whay they have it that way. There may have been a 3rd bed in 57 but if your shortening it to 114 WB then you need a 6.5' bed anyway which is their short step wood. |
11-20-2010, 06:14 PM | #18 | |
Hollister Road Co.
Re: wheelbase
11-20-2010, 06:22 PM | #19 |
Re: wheelbase
No groceries for me im always at the restaurants
Next week i will put my 1957 in the garage and look if i cut the FRAME to have 114 wb . or i keep the whell base to 123.25 inchs but there is more room in a 8ft compare to a 6.5 ft Box to put Racing part But i think the truck is nicer with a 6.5 box Last edited by DG Racing; 11-20-2010 at 06:23 PM. |
11-20-2010, 06:44 PM | #20 |
Re: wheelbase
11-20-2010, 08:23 PM | #21 |
Hollister Road Co.
Re: wheelbase
Long beds tow better
12-03-2010, 03:11 AM | #22 |
Re: wheelbase
ok so this is the answer i received from Mar-k
The long step 57 is a split year. Early models had an 89" bed. Later models had a 97" bed. Hope that helps. Webmaster So what i dont understand is imagine that i have a 1956 long bed that as a bed of 89 inchs with a wheelbase of 123.25 how can a 1958 with a 97 bed can have the same 123.25 wheelbase ????????????????????? Can somedody mesure there bed with a long wheelbase of 123.25 please |
12-03-2010, 03:22 AM | #23 |
Re: wheelbase
Ok i just find that yes 89 and 97 inch bed is right look
http://www.classicparts.com/Bed-Side.../products/100/ |
12-03-2010, 09:18 AM | #24 |
Hollister Road Co.
Re: wheelbase
Good research. I never new the long bed had two versions,
12-03-2010, 01:50 PM | #25 |
Re: wheelbase
OK so is there a member with a 55/59 Long bed on this forum ????
