Heater or AC resistor photo
1969 C-10, 350, with ac. Found this dangling near the firewall on the passengers side.
Is this the "remains" of my heater resistor? The fan powers up and down when I manipulate the fan control switch. The AC did not work when purchased from the PO. Anybody got a pic of "what it supposed" to look like?? ![]() Thanks...Rick |
Re: Heater or AC resistor photo
I just replaced my AC resistor and every other switch needed for AC and heater. I saw npthing that looked like that or even looked close. Maybe the PO put the wrong part in. The resistor should have two holes for mounting on the plate.?
Old Skool Club
![]() Join Date: Jun 2001
Don't have a pic, but like the previous post there's two screws that hold it in and the part will have a coil between two "posts". That coil is the resistor. What you're holding looks like a switch. Which switch? Don't know, but you can bet someone will....
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
454 MAKES IT ROAR
This is the resistor switch.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 10-25-2010 at 10:58 AM. |
Here are two more pics. Any idea as to what this is, or was? When I get home this evening, I'm gonna trace the wires down.
Thanks...Rick ![]() ![]() |
72 GMC
glove box light ?
is that a "push button' ? |
454 MAKES IT ROAR
Dude that's got to be it....
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Old Skool Club
Since I don't have a glove box light I didn't even think along that line. It makes sense, considering where you found it. There is a hole on the upper left corner of the opening. Is that where the switch goes? If so, where does the light mount? But, I think KEL is on the right track.
72 GMC
i don't have one either - it was an "inspired guess" !
I'll check as soon as I get home. The glove box light does make sense. I was browsing online and saw that the item is a plunger type of switch. The size matches, but I need to see about the wire colors.
Thanks for the help....you all are GREAT! Rick |
Back in the sticks
I can't see the pics at work, but there is an A/C switch that goes on the back of the plenum to turn your compressor on and off. If its a glove box light, the wires will be orange and white. If its the A/C it'll be different colors. I think they were green and possibly light blue? You can look at the color coded schematics in the electrical section to be sure.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#12 | |
Again I apologize about not having better details but there is another "hidden" switch on the AC system in our turcks.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#13 |
![]() Join Date: Nov 2004
Its is in fact the resistor that pulled apart.Mine did the same thing.
Behind here is the location: ![]()
1972 K-10 SWB Cheyenne |
#14 |
You got it!!!! Now...where does it go and which "lever" activates it? Hopefully, the remaining body for the switch is still mounted where it belongs.
Man...this restoration stuff is hard!! ![]() |
#15 |
Back in the sticks
It goes behind the plenum. The A/C-Heater lever activates it via a cam on the back. I'll try to find a pic of it in the assembly manual.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty Last edited by red71cheyenne; 10-25-2010 at 10:50 PM. Reason: Wrong lever |
#16 |
The switch is mounted on the diverter box. Here is a pic.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
#17 |
AWSOME!!!! Got home and checked the ac/heater unit. There it was. The carcas of the old ac compressor switch still screwed on the unit.
You guys are fantastic! Thanks a million! ![]() Rick |
