Old 10-25-2010, 10:43 AM   #1
Christiansok
Vacuum Questions...
Last night my Dad was showing me a little about timing and we ran into some weird (maybe not weird?) vacuum issues. I disconnected the vacuum line to the vacuum advance and plugged it while he was showing me the timing light and stuff. But with the truck idling we unplugged the vacuum line and it made no difference in how it ran/idled vs having it hooked up. My dad thought this was strange (idk maybe this is normal?) so I put my finger on the vaccum line, no suction at idle. Took the line off and cleaned a little bit of crud out of the end that was connected to the carb. Putting my finger where it was connected to the carb at idle, still no suction. I was wondering if this is normal or if my vacuum lines are hooked up wrong or perhaps something worse.
There are 4 spots on the front of my carb (4 barrel) where vacuum lines are connected. The lowest one near the base goes to the vacuum advance. Another line comes off and is plugged (assume it went to charcoal canister before). Then there is another line that comes out and hooks right back up to the carb about an inch away. Sorry I don't have any more specifics being at work but I can check stuff out when I get home later. Thanks.
Christiansok is offline   Reply With Quote
Old 10-25-2010, 10:56 AM   #2
rbagley
rbagley's Avatar
Re: Vacuum Questions...
I think the plugged port would have vacuum if you pulled the plug off. I'm running mine on the no vacuum at idle port because it was knocking a bunch on the other one.
rbagley is offline   Reply With Quote
Old 10-25-2010, 10:58 AM   #3
Zeke's Garage
Zeke's Garage's Avatar
Sounds like you've just connected it to a vacuum port located above the throttle plates. If you open the throttle just a bit, you should get vacuum on that port.
Most folks will state that you need to have the distributor connected to a ported- or always on vacuum port (Located below the throttle plates) for best results.
Zeke's Garage is offline   Reply With Quote
Old 10-25-2010, 10:58 AM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
A pic of the carburetor would help someone to pinpoint where the vacuum needs to be connected.
Member Nr. 2770
Old 10-25-2010, 10:59 AM   #5
geezer#99
geezer#99's Avatar
It's called ported or manifold vacuum. Ported is taken from above the throttle blades and shows no vacuum until the throttle is opened. Manifold is full time vacuum which is from below the throttle blades.
Old 10-25-2010, 11:31 AM   #6
Christiansok
I'll get some pictures of the carb on my lunch break and post them to help.
Is there a preferred method (ported/manifold) of vacuum? Assuming switching mine doesn't cause any pinging or other problems like rbagley mentioned. The way it is hooked up now it seems to be running ok.
Old 10-25-2010, 11:46 AM   #7
danleaman
Ported vacuum for your advance, if you connect your vacuum advance to manifold vacuum, you will have have full advance at idle. Ported is above the throttle plates and only becomes active when the throttle opes.
Dan
danleaman is offline   Reply With Quote
Old 10-25-2010, 12:44 PM   #8
Christiansok
Here are some phone pics of my carb setup
The line on the lower left is the one to the vacuum advance. And you can also see the line that comes out and loops right back to the carb.
