10-25-2010, 01:35 PM | #1 |
Need some pictures of center bolt covers
I am looking for ideas on running the plug wires using a center bolt valve cover. IF you have this application can you please post up your set up
2013 Chevy Silverado, Z71, 5.3L, 4 door 2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40 Support the Troops. |
10-25-2010, 03:26 PM | #3 |
Happy to be here
Re: Need some pictures of center bolt covers
On my Ramjet 350 we ran them down and back.
10-25-2010, 03:47 PM | #4 |
great ideas.
I cant run the center bolt holders as the covers I have, the bolt head is sunk in the cover to mount flush. I would need to fab some sort of holder and mount it to a open intak bolt. or run down and then back. But then I would need to shield the wires from the head heat.
10-25-2010, 03:50 PM | #5 |
On a budget like Fred Sanford
I run mine under the headers with little plastic clamps, works good and much cleaner being hidden IMO.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
10-25-2010, 03:51 PM | #6 |
here's what i used.their a little hard to see.but,i get compliments on em.they also sell a adapter plate thingy ma jig that allows you to run traditional pattern.but,it's spendy.
" Never look up a dead dogs butt." |
10-25-2010, 04:09 PM | #7 |
Here's what I ended up using
10-25-2010, 04:45 PM | #8 |
10-27-2010, 04:12 PM | #9 | |
I think I might try this.... the clips are the basic ones I assume. How did you mount them under the headers?
10-27-2010, 05:12 PM | #10 |
My plug wires look terrible
1972 GMC C10 |
10-27-2010, 10:23 PM | #11 |
Yep they are just basic wire separators. There's a small unused threaded hole on each side of the block that I screwed a 1"x3" piece of aluminum sheet metal to, they keep the wires against the block and away from the headers. Been on there that way for 35k miles and haven't come close to hurting a wire.
10-28-2010, 07:05 PM | #12 |
.. !WAR FEDOR! ..
i ran them under the headers, nothing fancy.
"san diego chargers #1" Last edited by joe1982; 10-28-2010 at 07:09 PM. |
11-08-2010, 01:46 PM | #13 |
Well all I tried to run the wires down but they come way to close to the headers. I would have to run sleeves or something on the wires. Anyone can post the venders that they purchased the looms from? I called summit and jegs no luck.
running a pair of headers I had at the garage not sure the brand....
