67/68 Core Support On A 69-72 Frame Q?
I've never crossed this bridge before.I'm building a '67 GMC-lookin' truck off a '71 frame.I figured the core support mounting kit should be a 67/68 type for the correct bushings to get the right height off the frame.I'm wondering what people do about the bigger holes in the frame brackets on a 69-72,since the 67/68 washers are about the same size as the holes.I figure just find bigger diameter fender washers or make plates.Is there a simple commonly done solution I don't know about?
VA72C10
![]() Join Date: Mar 2008
Re: 67/68 Core Support On A 69-72 Frame Q?
good question and probably FAQ fodder when it's answered
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
Anythong can be done,right?
cut the '69-'72 rubber mounts down to the proper thickness, which is about 3/4" compressed
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Burnouts are therapeutic
from what I have read here you are suppose to match the bushings to the frame and not the sheetmetal. 69-72 frame uses 69-72 bushings regardless of sheetmetal.http://67-72chevytrucks.com/vboard/s....php?p=4243502 here's a link to a post on similiar question.
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
That one answer that says all supports are the same is wrong.The 69-72 core supports are shorter top to bottom.This is due to the 67/68s having a splash pan,I believe.I've been told by experts to go with what core support you are using.Cutting down the later bushings does sound like a good way to go.It figures I'd end up with 2 67/68 mount kits and no 69-72s.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 10-27-2010 at 08:55 AM. |
Not sure if this will help but a 67-68 core support on a 69-72 will work for everything but your headlight alignment and bezel around the headlight. These will be to high, as mentioned because of the 69-72 are shorter top to bottom.
Now ask me I how I know... |
If I remember correctly, I built a '71 with a 67/68 front clip and ended using the 71's core support. I think I just drilled out the welds and removed the 69/72 headlight buckets. I might of messed with the mounting bushings, but I don't remember. I used the 67/68 hood latch. I do remember it was no trouble to do. Bolted on the fenders and the hood, I reused the headlight hardware, but had to shorten the adjuster screws.
Dano
![]() ![]() It ain't yours, if you didn't build it! |
![]() Join Date: May 2007
I put a 68 clip on a 72 frame and used 72 core support bushings with no problems....... sheetmetal lined up perfectly
