Old 10-25-2010, 02:21 PM   #1
Heinz55
Heinz55's Avatar
Serpentine belt conversion question?
picked up a 1979 SB 350. I wanna go with a serpentine belt set up, but can't afford aftermarker bling and chrome with the associated $$$ cost.
I have heard that late model GM serpentine set upd (Blazer, s-10, caprice, etc) will work on the 350 block. If so, I can get all that at the junkyard for about $100 or less, some powder coat "chrome", and I should be fine.
Will this work, or is the swap not that painless?
Thanks in advance for any help
During first and only engine rebuild " That O-ring? It's a spare I think, but lets keep it just in case we discover we need it"
1955 Chevy 2nd series, "Mabel"
Heinz55 is offline   Reply With Quote
Old 10-25-2010, 02:39 PM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Serpentine belt conversion question?
should work fine, provided the heads have the bolt holes in the right spots, which they should.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 10-25-2010, 03:21 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
There was a thread recently on the subject that had links to older posts as well. Unfortunately I can't find it right now. Do some digging and you should get all you need to know and more...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-25-2010, 03:59 PM   #4
Heinz55
Heinz55's Avatar
Thanks, though I remebered reading it, this makes the engine a lot cheaper to rebuild now
Old 10-25-2010, 04:47 PM   #5
Pop's C-10
Pop's C-10's Avatar
don't for get to get tha reverse flow water pump to go along with tha set up
Pop's C-10 is offline   Reply With Quote
Old 10-25-2010, 05:41 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Try these-
LINK
LINK
LINK
Articles-
"Refining Sierra"
Old 10-25-2010, 06:38 PM   #7
benoit454
Chris
benoit454's Avatar
if you run a mech. fan the fan has to match the reverse flow.
I think it looks alot cleaner without sepr. setups, all them big brackets and pulleys. But it gets the job done.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 10-25-2010, 07:45 PM   #8
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
This serpentine question comes up all too often.
Here is another helpful link.
http://67-72chevytrucks.com/vboard/s...d.php?t=233335
You can also find info>>>>>
The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ > FAQ Truck Tech > Engine and Drivetrain and pick Serp Setups from the list.
DirtyLarry is offline   Reply With Quote
