Were all trucks with this molding 2 tone?
I'm trying to figure out how my '73 was originally painted, I'm pretty sure there was no red. The interior is silver kinda like the outside but it doesn't quite match. (pretty sure that's factory)
Did all of the trucks with this side molding come from the factory in 2 tone paint? Or - did all "Cheyenne Super" trucks have 2 tone paint?
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's. You can set my truck on fire and roll it down a hill, and I still wouldn't trade it for a Coupe de Ville. |
Arrived on a Pale Horse
Re: Were all trucks with this molding 2 tone?
Can't answer the part about the Cheyenne, but not all trucks had 2 tone with the trim. My stepdad worked for Borg Warner when I was a kid (in the 70's) and he bought several of these new. One was dark green, not two tone, had the side mouldings. I remember him driving down the embankment and driving it in the White River!
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
yea,i remember seeing them solid with that trim.where you at in oregon ? that pic looks like hillsboro/forest grove? nice truck by the way i like it.
" Never look up a dead dogs butt."
yor rpo or spid sticker will id what it came with from the factory. heres a link http://www.chuckschevytruckpages.com...s_1973-87.html
What color is the inside of the cab, is it still original? Pics would help.
Andrew 1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10 1988 C1500 Scottsdale 305, 700R4, 3.08 1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10 |
Slots go on anything!
My '74 is solid at the bottom with the trim, but it does have a white roof. My 79 Scottsdale and '75 blazers were the same way.
1974 Jimmy- 5.3/4L80e/NP241 |
#7 | ||
That pic is out on the back roads behind Newberg.Unfortunately I don't have that. ![]() Quote:
On the two tone trucks, did they paint the entire truck one color, and then add the second? I see some evidence of white paint showing through between the bed and cab...is it possible that's primer?
From what I've seen, it appears they sprayed one color without masking. Then masked off the areas that were to stay the 1st color and sprayed the 2nd color. I doubt they wasted paint by trying to get complete coverage with the 1st color in areas that were to be painted over with the 2nd color. But there would be a considerable amount of 1st color "overspray" underneath the 2nd color.
Usually the cab interior paint color is the same as the primary outside color;your firewall and cowl also will also indicate ptimary color.
The upper and lower mouldings were standard on Silverado The upper moulding was standard on Cheyenne The 2 tone RPO code would be ZY3,ZY4 or ZY5 If no RPO was specified the truck came 1 color. Above applies to 1980 trucks .... |
Took some stuff off the firewall tonight and found some more of the blue/silver color. That must have been original. (somebody rattle canned the rest of the engine compartment black) I see just a hint of white on the corners of the fenders, and around the window drip molding. Must have been silver and white. Glad they painted it...
| Bookmarks |
