Old 10-25-2010, 10:14 PM   #1
Rusteeze64GB
Engine Oil
What kind of engine oil are some of you guys using. Looking to see what you inline 6er's are using. About to do an oil change. Oil pressure is low, but have not changed the oil in a while. Just curious. Thanks in advance.
Rusteeze64GB is offline   Reply With Quote
Old 10-25-2010, 11:20 PM   #2
bubba327
HOW long until spring??
bubba327's Avatar
Re: Engine Oil
Temperature and use should determine the viscosity. I'm using 10-30 going into winter here in Idaho.
How low is your pressure?
Normal for my 230 I-6 is about 40-50 lbs.
I think I checked the manual awhile back and that was accepted range.
Any body have a service manual handy??
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 10-25-2010, 11:33 PM   #3
daverod
SSN 706
daverod's Avatar
Re: Engine Oil
10w30 syntec
daverod is offline   Reply With Quote
Old 10-26-2010, 12:02 AM   #4
irish1966
irish1966's Avatar
Re: Engine Oil
Originally Posted by daverod View Post
10w30 syntec
X2 with Daverod
(no Champion plugs, and always a K&N filter)
Cheers
David
66 LWB Fleet (on hold)
64 LWB Fleet (daily driver)
65 SWB Fleet (almost finished as a driver)
64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck)
Nothing worth doing, is easy.
irish1966 is offline   Reply With Quote
Old 10-26-2010, 10:52 AM   #5
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: Engine Oil
A lot of motor oils don't have the wear additives for a flat tappet cam anymore.
http://www.hotrod.com/techarticles/e...ech/index.html
Mobil 1 says their 15w-50 has enough for older motors. After a good break-in period with dinosaur oil and ZDDP additive I run the Mobil 1.
http://www.mobiloil.com/USA-English/..._1_15W-50.aspx
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 10-26-2010, 11:19 AM   #6
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Engine Oil
I ran straight 40 in my 65 with an I6. My engine had real low pressure and low compression. Im sure it was just wore out.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-26-2010, 11:19 AM   #7
Texasdeere
Texasdeere's Avatar
Re: Engine Oil
I live down south and use 30w or 15w40 diesel oil in my old truck and tractor engines.
Texasdeere is offline   Reply With Quote
Old 10-26-2010, 11:32 AM   #8
bama63
bama63's Avatar
Re: Engine Oil
15w40 delo 400 diesel oil has all the wear additives needed for our older engines
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 10-26-2010, 04:57 PM   #9
62 Longbed
62 Longbed's Avatar
Re: Engine Oil
15w40 Rotella or Delo 400 diesel , like bama63 .. this oil has all the wear additives needed for our older engines .
62 Longbed is offline   Reply With Quote
Old 10-26-2010, 07:01 PM   #10
andyh1956
Re: Engine Oil
i use 15 w 40 rotella in every engine i own, have for years.
andy
andyh1956 is offline   Reply With Quote
Old 10-27-2010, 07:04 AM   #11
C-10cutty
C-10cutty's Avatar
Re: Engine Oil
15w40 diesel oil in my 235 and Dart 273, good for old motors.
C-10cutty is offline   Reply With Quote
Old 10-28-2010, 11:20 PM   #12
bubba327
bubba327's Avatar
Re: Engine Oil
Good info here guys , I never thought about using diesel oil.
Anybody using Marvel Mystery oil ? Or other additives??
Old 10-28-2010, 11:50 PM   #13
jake wells
Re: Engine Oil
I just use Pennzoil 10W30 in everything i own except my mowers i use HD30 in them.
I add a little about 8oz per oil change of STP oil treatment with everything and use good quality WIX filters.
Every month a add a bottle of fuel injector/carb cleaner to my gas tank and then every 12 months i use seafoam.
jake wells is offline   Reply With Quote
