Old 10-25-2010, 10:48 PM   #1
1970CHEVYc10
1970CHEVYc10's Avatar
What is this and does it need be wired up?
Is it a fuel pump or filter? Its next the gas tank.. It has a single black wire runnin to the fire wall but it is not connected to anything.... This on my 1970 Suburban.... Plz let me kno... thanks.
1970 Chevy C10 LWB fleetside
1970 Chevy 3 door Suburban
1970CHEVYc10 is offline   Reply With Quote
Old 10-26-2010, 12:34 AM   #2
mosesburb
I had a V-8
mosesburb's Avatar
Re: What is this and does it need be wired up?
It appears to be a very old electric fuel pump. The wire not being hooked up to anything obviously shows it is not being used so, if it were on mine, I would remove it from the system to prevent it from causing any flow restriction problems.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 10-26-2010, 05:00 PM   #3
69burbin
Maybe its a old filter with a water in fuel light , it would ground that wire if it had water .
69burbin is offline   Reply With Quote
Old 10-29-2010, 11:07 PM   #4
mdgraham1973
mdgraham1973's Avatar
where is this located? I can tell on the frame but where at on the frame???
mdgraham1973 is offline   Reply With Quote
Old 10-29-2010, 11:46 PM   #5
vectorit
What?
vectorit's Avatar
Looks just like the electric fuel pump that was on my burb for years, and it was located on the drivers side of the frame near the front door.
Took it off, since I felt it was no longer needed.
Back in the day, my Dad put it on because we had fuel problems in the heat of the summer in the high altitudes of the Sierra Nevada.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-07-2010, 09:31 PM   #6
1970CHEVYc10
Thanks Guys..... It is located on the frame near the gas tank at the rear of the suburban...
Old 11-08-2010, 08:24 AM   #7
1956cameo
1956cameo's Avatar
That is definately an old electric fuel pump. I had two suburbans with pumps exactly like that. Since you are obviously recieving your fuel in a different way I would take it off.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
