03-01-2003, 06:52 PM | #1 |
rear end Qs??
Picked up a rear end core to build up today, started to strip everything down.....hit a hangup. When I went to remove the axles, I took out the lock screw but the cross shaft will not come out of the carrier. It's a stock Chevy open diff., anyone have any ideas on what could be holding it up or am I completely missing something??
Also anyone know of a 12 bolt truck specific rear end rebuild guide, I have a couple generic type things, but nothing for just the 12 bolt Thanks
1968 C10 - 383, non-stop project 1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies |
03-01-2003, 07:05 PM | #2 |
Fabricate till you "puke"
The lock screw has a smooth end on it (no threads), approx 1 1/2" long..........did it all come out?
03-01-2003, 07:08 PM | #3 |
yeah, the whole thing came out. can the cross shaft go in/out on either end of the carrier? it will wiggle front/back but not left/right (if it was installed in a truck)
03-01-2003, 08:35 PM | #4 |
GYRO GEARLOOSE
Either end will do.
Nevada City, CA Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB |
03-01-2003, 09:22 PM | #5 | |
"Ochre Ogre"
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
03-01-2003, 09:58 PM | #6 |
Same here
Also on my 70 the pin will only come out 1 way (I'm serious).This is the only 1 I have that is like that
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
03-01-2003, 11:47 PM | #7 |
Sometimes the pin varnish's up, and can be a bit tight to remove.
I'm working on a 12 bolt now that was that way, just take your time and try to clean around the pin or use brake cleaner to help brakeup the varnish. Good luck
69 swb stepside, rebuild and upgrade in progress |
03-02-2003, 06:35 PM | #8 |
thanks for all the help, I looked closer at the lock screw and it does look like some of it broke off. how far into the cross shaft does the lock screw go? now i just need to find a small enough magnet or something to dig it out of the carrier.....or just bust out the BFH to pound the cross-shaft out
03-02-2003, 07:13 PM | #9 |
Well, the hole goes all the way through the cross pin.......i havent measured the depth, but beleive the retainer bolt/pin also goes into the carrier on the other side. They can be a pain.....goood luck,crazyL
03-03-2003, 03:27 PM | #10 |
Somebody sells a tool now for getting this out. Check with Randy's Ring and Pinion. Broken shaft screws are a PITA.
03-03-2003, 03:45 PM | #11 |
It's a catastrophic success.
if its not the bolt broke off check for a groove where the spider gears wear, makes a notch that holds the pin from sliding out
