Old 10-26-2010, 06:21 AM   #1
FL71C10
Need help with SB engine mounts
I am putting a 350 out of a 75 impala in my truck. The engine mounts on the motor are the newer style with bolts that go through the mount sideways. My truck has the original engine stands. Do I just replace the mounts on trhe block with original 71 truck mounts and then the motor will bolt right up to my truck. It's a TH350 transmission.
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 10-26-2010, 06:43 AM   #2
raycow
Re: Need help with SB engine mounts
Yes, it will be easier to use the stock mounts for the truck. Trucks started using the clamshell mounts in 73, and the frame brackets for those don't fit the earlier crossmembers without modification.
Ray
raycow is offline   Reply With Quote
Old 10-26-2010, 07:49 AM   #3
FL71C10
Thanks, Ray. Trans mount is ok, right?
Old 10-26-2010, 08:44 AM   #4
JimmyFloyd
Yeah, my 70 had a 70 impala 350 in it and uses the original truck engine mounts.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 10-26-2010, 08:51 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Scratch this post... I think I would have only confused people with it so I edited it out.
LockDoc
Leon
