Need feedback on starter problems: new starter, or new battery? My symptoms are....
Here's my problem:
recently I've had problems with my burb starting (after driving it for 5 minutes, two miles, or longer periods of time). If I jump back in to start, it turns over - real slow, maybe 3-5 times, but will not start. If I wait for awhile (15 minutes) - it turns over and starts. Trying to figure out if it's a hot start problem (and starter is going bad) or a battery problem. Used to have headers (now manifolds) - which created hot start problems, so maybe the starter is going bad? Cold starts - no problem. Burb sits for a week, or two at times. Same thing was happening to a buddy of mine, his problem was the battery (so he thinks it's a battery problem). I've been wanting to put an AC Delco battery in it - just thinking I might start there, at least I know I will have a fresh, new battery (since I have no idea how old it is, and I usually take road trips and I'm far off the beaten path). Any thoughts, suggestions?
Doug '72 GMC K2500 Suburban 4x4 |
The Older Generation
Re: Need feedback on starter problems: new starter, or new battery? My symptoms are..
I guess I would start buy taking all of the cables off and cleaning all of the contact surfaces really good, including the ground at the motor and the positive cable at the solenoid. Then fully charge the battery with a battery charger. It does sound like a heat sink problem but I guess it would be compounded if the starter or battery was getting weak...
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-26-2010 at 12:44 PM. |
I have been hunting down the same prob on my 67 for about 6 months
It was the negitive battery cable where it bolted to the motor |
lots of people spend hundreds of dollars chasin electric problems when cleaning the contacts is all that is needed// lots of guys think lookin at connections is good enough. but unless you have xray vision lookin aint checkin as far as good contact is concened
each battery cable has two ends another fact that eludes some people
Junior Member
Very good suggestions. I also found that corrosion builds up in the cable inside the insulation.
I recently had similar problems so my fix was to replace the old positive and negative cables. I also cleaned all contact points of the cables.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Could be it, could not be it. The battery I mean. I had the same problem in my '99 old body style truck here a while back. Check with a meter or go to a local parts store and have them check your cranking amps.
#7 | |
Gone to greener pastures
![]() Join Date: May 2007
Took me over a week to chase that down.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
sharp as a marble
![]() Join Date: Jan 2007
I agree with all of the above. If you have a DVOM, you might do a voltage drop test. One lead on the battery post, and the other on the battery terminal. If you see more than .5 volts it is a bad connection. Might suggest checking the timing as well, too much timing will make an engine drag hot, but might not when cold. IMO, I would do the obvious first. CLEAN every battery connection until shiny, and see what happens.
Thanks for all the suggestions... I'm going to spend some time on it over the weekend. I'll let you know what I find out.
Thanks, Doug
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I would first do like everyone else is suggesting. Clean the terminals and connections. Then use a good electrical grease on them when you hook them back up. If that doesn't solve your problem, then what you are discribing is a heat soak problem with the starter solenoid. Change that and you should be good to go. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Old Skool Club
![]() Join Date: Jun 2001
Corrosion that builds up within the housing of the battery cables is difficult to see, but it will happen over time.
Heat soak affects the starter solenoid of a hot engine. For my truck, there was never a problem with heat soak until I change intakes and carburetors. Going from an Edelbrock 1405 on an adapter on the stock Q-Jet intake, to an Edelbrock 1901 on an Edelbrock Performer intake....made heat soak an issue. The Q-Jet was so much leaner than the 1405, and that made for a hotter mixture. Put a heat shield on the starter and problem was solved.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
