Old 10-26-2010, 08:19 PM   #1
DBear
DBear's Avatar
Lights Issue
I have a Chevy '71 Burb, and I am putting a 67 GMC front clip on it. My dilema is that the GMC setup is dual headlights and the burb is a chevy. How can I wire the headlights up so it will function correctly. My harness has the factory single headlight setup. How and what to do????
DBear is offline   Reply With Quote
Old 10-26-2010, 09:00 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Lights Issue
Why not just buy a harness for a gmc?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-26-2010, 10:00 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Lights Issue
Smitty
Why not just buy two relays and a couple of fuses and wire it like this.
With this setup you just use the high and low beam wires in the harness to trigger the relays then the relays will light the four high beam elements and the two low beam elements.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-29-2010, 02:24 PM   #4
DBear
DBear's Avatar
Re: Lights Issue
ttt
Old 10-29-2010, 04:26 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Lights Issue
What, you didn't like VetteVet's diagram? Easiest way (not the best way.... you should add relays) is use your existing 3-prong headlamp pigtails for your new high/low lamps... then get a couple two-prong pigtails for your inner (high only) lamps and splice them into the high and ground wires of your 3-prong pigtails.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 10-30-2010, 05:31 AM   #6
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Lights Issue
I would suggest following VettVets diagram and add relays. It will give you better light output and reduce to power draw running thru the headlight switch. A win win situation.
Rich
1972 K5 Blazer CST Click HERE
