Old 10-27-2010, 10:00 AM   #1
Sonicman
Sonicman's Avatar
Question Manual to power brakes
I am going from manual brakes to power brakes. The new booster and master came already assembled. Do I need to separate them and bench bleed the master? Can someone give me a how to on bench bleeding?
Sonicman is offline   Reply With Quote
Old 10-27-2010, 11:33 AM   #2
stich626
Re: Manual to power brakes
you'll need to take the master off..
and go to napa or others and get the bleading kit,
unless it came wuth your set up
it's 2 rubber hoses and fittings to screw into the ports of the master,
the rubber hose goes from the fittings in the ports to the master so when you pump the master, the fluid goes back into the master..
if you don't have the kit to blead they are very cheap
stich626 is offline   Reply With Quote
Old 10-27-2010, 05:28 PM   #3
Sonicman
Sonicman's Avatar
I got it all done but I had to make my own hoses. I went to four different auto stores and know one knew what I was talking. Oh well I got power brakes now!!!!!!!!!!!!!!!!
Thanks bud!!!!!!!!
