Old 10-27-2010, 11:14 AM   #1
brawley
Easy Does It
brawley's Avatar
exhaust system set up?
does anyone have any pics. of the way there exhaust is set up, not sure the route I want to go yet? any recomendations?? thanks
brawley is offline   Reply With Quote
Old 10-27-2010, 11:46 AM   #2
badriand
badriand's Avatar
Re: exhaust system set up?
From intake back or? My truck had headers when i got it but i couldn't get those off fast enough. Went back with ramhorns and set of turbos dumped before the axle.
badriand is offline   Reply With Quote
Old 10-27-2010, 12:34 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
In a coincidence, I just took this photo for a friend who asked a similar question this morning...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-27-2010, 04:44 PM   #4
66GTO66C10
66GTO66C10's Avatar
Here is the route I took.
1966 Chevy C10 frame off resto (In progress)
1966 GTO Numbers matching original
1989 Toyota Pickup (Tonka) resto
2002 HD FLSTC
2000 HD FLSTC
1996 Ninja ZX11
Believe nothing of what you hear, and 1/2 of what you see!
66GTO66C10 is offline   Reply With Quote
Old 10-27-2010, 04:54 PM   #5
lakeroadster
More data in my build thread... and an audio clip too!
lakeroadster is offline   Reply With Quote
Old 10-27-2010, 07:34 PM   #6
66redw/white
made in america
66redw/white's Avatar
what motor do you have?
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline   Reply With Quote
Old 10-28-2010, 09:26 AM   #7
badriand
badriand's Avatar
I have never seen exhaust ran out the sides of the frame. Does that cause in heating issues on the tires or under the cab sides?
Old 10-28-2010, 11:19 AM   #8
brawley
Easy Does It
brawley's Avatar
I have a 350/350 combo with long headers. I thought about a short style that exits out in front of the rear tires, but wondered about getting fumes in the cab, i liked 66c10 full length set up though. never seen a set up like the first pic. but seems like a good idea. thanks for the input!
Old 10-28-2010, 11:33 AM   #9
vin63
vin63's Avatar
I've built a few exhaust systems that way for others, and it was the most practical way for me to route 3-inch tubing while keeping everything at, or above, the bottom of the frame, and mounting the mufflers under the bed to reduce drone in the cab. Plus, it opened up additional room between the frame rails under the cab for other items, like an trans oil cooler and my air solenoids, etc.
Old 10-28-2010, 11:38 AM   #10
irish1966
irish1966's Avatar
How close did u have to get the pipe to the frame? I'm just tryin to visualize doing it with everything on the truck.
Cheers
David
66 LWB Fleet (on hold)
64 LWB Fleet (daily driver)
65 SWB Fleet (almost finished as a driver)
64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck)
Nothing worth doing, is easy.
irish1966 is offline   Reply With Quote
Old 10-28-2010, 11:47 AM   #11
markeb01
Senior Enthusiast
markeb01's Avatar
Here’s mine – ram horn manifolds with 2 ¼” pipes leading to Flowtech Terminator mufflers and turn downs ahead of the axle:
Old 10-28-2010, 11:52 AM   #12
irish1966
irish1966's Avatar
U running stock height Markeb??
Cheers
David
Old 10-28-2010, 11:52 AM   #13
vin63
vin63's Avatar
I initially fabricated the exhaust with all of the sheetmetal still mounted to the chassis. This way, I positioned the tubing in the middle of the peak where the cab floor braces start their angles down to the rocker panel. Here are a couple of photos during fabrication that might help better explain...
Driver's side...
Old 10-28-2010, 11:56 AM   #14
irish1966
irish1966's Avatar
Driver's side...
That's exactly why I was asking the question. Thx man. That is a perfect picture. I like the idea, especially when 1. it keeps the drone from the cab, and 2. It means less twists and turns down thru the frame. Nice work my friend.
Cheers
David
Old 10-28-2010, 12:03 PM   #15
vin63
vin63's Avatar
Thanks...happy to help.
Old 10-28-2010, 12:05 PM   #16
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
These are 4". I can try and add more of my system later. The fumes in the cab are not too bad when stopped at a light. I dont notice any while driving.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-28-2010, 12:27 PM   #17
markeb01
Senior Enthusiast
markeb01's Avatar
Yes relatively stock, here's a shot of how it sits:
