Air in the heater core?
Ok I def have some air trapped in the heater core how do i get it out?
Thanks Alan |
Parts and more parts
Re: Air in the heater core?
You can sweep the air out with a good flow through the core. Most shops are now using a vacuum to evacuate the cooling system and then filling it from open jugs with a suction tube. This is necessary for many of the newer vehicles to get the water to thehigh points.
Especially since the radiator is lower than the engine.
Frank |
One day...
![]() Join Date: Apr 2008
Could put the truck on ramps which will put your radiator higher, ive had to do that on a couple side job cars i did because they were such a pain to get the air out
^ that'll do it, same as air trapped under the thermostat.
| Bookmarks |
