10-27-2010, 06:24 PM | #1 |
Serial Number
Where is the serials numbers on a 1957
10-27-2010, 06:36 PM | #2 |
Re: Serial Number
Your truck should have the vehicle identification number stamped on a stainless steel plate that is attached on the left front door hinge post.
Also check the driver side frame directely across from the generator, area. The number is be stamped in, Wire brush this area and it should appear. |
10-27-2010, 11:36 PM | #3 |
Re: Serial Number
The frame number can also be under the cab on the drivers sid. That's where it is on mine.
Kim Last edited by Kim57; 10-27-2010 at 11:36 PM. |
10-27-2010, 11:56 PM | #4 |
Re: Serial Number
ok yes its on the driver side frame directely across from the generator, area.
but on the stanless blue plate attached on the left front door hinge post its only gvw rating and color paint no. no plate with serial number on it ?? |
10-28-2010, 12:23 AM | #5 |
Re: Serial Number
Higher up, in the door jamb area of the windshield frame, driver's side
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ Last edited by bobinbc; 10-28-2010 at 12:24 AM. |
10-28-2010, 01:55 AM | #6 |
CLASSIX Truck Club
Re: Serial Number
My 55 was right on the upper part of the cab door jam, and my 59 had it on the cab inside the door jam between the 2 door hinges.
11-16-2010, 06:24 PM | #7 |
Re: Serial Number
Can someone post a picture of what the vin plate in the drivers door frame looks like in a 1957 Chevy
Want to see exactly what one looks like. thanks |
11-16-2010, 07:40 PM | #8 |
Re: Serial Number
Here's what's on my 1959. My apologies if the 59 is not the same as the 57.
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
11-17-2010, 01:21 AM | #9 |
Re: Serial Number
Here's the one on my cab. I believe it's a 55 but the one on my original 57 cab was identical.
Kim Last edited by Kim57; 11-17-2010 at 01:26 AM. |
11-20-2010, 01:00 AM | #10 |
Re: Serial Number
ok thanks for the pictures
