Old 10-27-2010, 09:17 PM   #1
ChevyLvr4Life
ChevyLvr4Life's Avatar
Vent shade install ?
I bought a new set of vent shades recently and noticed that they came with some clips. I know the clips are used to attach them to the doors, but don't know where they are suppose to go. Do you pull out the door glass rubber, put the clips in, and then put the rubber back?
Thanks in advance!
1970 Chevy C10 LWB 307 3OTT 3.73 gear
ChevyLvr4Life is offline   Reply With Quote
Old 10-27-2010, 09:25 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Vent shade install ?
mine screwed into the doors..(took em off and welded up the holes)
Good luck
John
1999 Toyota Tacoma 4x4
Old 10-27-2010, 09:43 PM   #3
ChevyLvr4Life
Good luck
I thought about doing that ( using screws ) if I can't figure out the clip thing.
Old 10-27-2010, 09:43 PM   #4
Hubscrub
Cruzin
Hubscrub's Avatar
i agree the ones i got screwed into the door with three small screws maybe they have elimated doing that (not a bad thing)
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 10-28-2010, 07:48 AM   #5
Sammy
Thanks in advance!
Bought my set a long, long time ago. Came with clips, used them. Have in the past removed them for other reasons, then reinstalled them when finished. Use the clips!
Clips under the rubber door seal, out of site.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 10-28-2010, 10:42 AM   #6
ChevyLvr4Life
Thanks Sammy!, That's the answer I was lookin for. My door glass rubber needs replacing anyway, that will be a good time to install them.
