Old 10-27-2010, 10:53 PM   #1
68stepsidenhaysvll
painting frame
Has anybody heard of por15 from what i have you can brush it on. Has anyone used it or know if it is a reliable product.
68stepsidenhaysvll is offline   Reply With Quote
Old 10-27-2010, 10:58 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: painting frame
yes and yes
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-27-2010, 11:39 PM   #3
mwilliams5891
Re: painting frame
any ideas how many quarts it would take to do the frame?
and do you prep it like you would any other painting surface?
not trying to highjak thought it was close enough
-1969 C/10 Short Step soon to be Brand NEW Ls6/T56
-03 Mazda Protege 5
-WTB 1970 Chevelle project
mwilliams5891 is offline   Reply With Quote
Old 10-27-2010, 11:49 PM   #4
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: painting frame
1 quart will do the whole frame brushing it on. Put it on thin otherwise it will bubble and look bad. Prep the frame by cleaning it with a wire wheel or wire brush. You can also use POR 15 prep. One thing to keep in mind is that POR 15 is not UV safe so you can't leave it in the sun or it will turn milky white, so you need to spray paint over it. There is a lot I am leaving out but overall it looks really good when it's done. Oh yeah.......DON'T GET IT ON YOUR HANDS!!!!!!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 10-27-2010, 11:49 PM   #5
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: painting frame
just put 2 coats on tonight, used foam rollers and brushes, shines great, and the durability is huge from the research I've done, used 3/4 of a quart, plan on 2 more coats and rustoleum gloss black when the fial coat is setting up to protect from the UV damage seems to be the easiest way
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 10-27-2010, 11:51 PM   #6
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: painting frame
I think they do make a UV freindly version now.
Old 10-28-2010, 01:13 AM   #7
heyray
heyray's Avatar
Re: painting frame
I wouldn't put rustoleum as a top coat. no need to topcoat a frame wont see much sun did mine years ago still looks good
72 Blazer 4wd
72 Blazer 2wd
69 Blazer 4wd
easy to take apart hard to finish.
Ray of all trades master of none.
heyray is offline   Reply With Quote
Old 10-28-2010, 01:33 AM   #8
stich626
Re: painting frame
here you go read up..
I'd use there starter kit, with their metal prep and clean..
read up..
http://www.advanced-rust-protection.com/index.html overall page
http://www.advanced-rust-protection....storuspor.html how to use page
the dos and don'ts
http://www.advanced-rust-protection....stordosan.html
facts and tech info'' page..
http://www.advanced-rust-protection.com/faqs.html
great stuff,, read up..
stich626 is offline   Reply With Quote
Old 10-28-2010, 08:23 AM   #9
tantrumpipeline
Re: painting frame
Many guys on the board have done this to protect it, but if you have some pics of yours I would like to see them, that'd be one less step for me to do and I like that idea
20 Duramax tow pig
52 short project
Old 10-28-2010, 09:04 AM   #10
mrhino
Re: painting frame
Check out my build thread, I used a product called KBC. (first couple photos) http://67-72chevytrucks.com/vboard/s...d.php?t=427417
they have a hand full of diffrent colors to choose from. I never used POR15 but I hear they are very close to the same thing. and KBC was a little less costly.
mrhino is offline   Reply With Quote
Old 10-28-2010, 09:20 AM   #11
LeatherMan69
Re: painting frame
I actually just used a paint on or spray on product called 'Chasis saver' comes in different colors and applies really well. I chose gloss black and got to say looks good for an old pitted frame!
LeatherMan69 is offline   Reply With Quote
