Old 10-28-2010, 01:48 AM   #1
shiner2001
shiner2001's Avatar
pic and info request -- 76-78 Caddy El Dorado brake calipers for rear disc conversion
I just ordered a set of captainfab's brackets to convert my rear drums to discs on my 72 and am looking to source my calipers from a 76-78 El Dorado so that I can have an ebrake (to be set once a year to pass safety inspection...if they even actually check it, but better safe than sorry). It's looking to be pretty pricey to buy the caliper set up with the e-brake brackets in place, but I'm trying to see how exactly they work so that I can fab my own e-brake set up. If anyone has these calipers, either mounted or not, and can post some pictures, that would be great. Basically I am looking to see how the e-brake brackets and springs are mounted, as well as what they actually do when the pedal is set, so that I can start work on making my own. The caliper that I am looking at starting with is this one, Cardone #18-4116.
Any info helps!!
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline   Reply With Quote
Old 10-28-2010, 03:08 AM   #2
stich626
Re: pic and info request -- 76-78 Caddy El Dorado brake calipers for rear disc conver
I'd get the one with the brackets already on it..
stich626 is offline   Reply With Quote
Old 10-28-2010, 03:16 AM   #3
shiner2001
shiner2001's Avatar
After looking around for those, I'm not sure that when you buy the caliper that it comes with the e-brake bracket after all. I think that may be why it's recommended you keep the brackets if you turn in a set of these for a core charge.
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 10-28-2010, 05:23 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
just for your info... you NEED to set the E-brake from time to time on those... that's what adjusts the rear brakes. If they don't get used, they won't adjust and will end up freezing in place.
Old 10-28-2010, 05:47 PM   #5
shiner2001
shiner2001's Avatar
Roger that. Good info.
Derek
79 Scout II 345
01 GMC Yukon 5.3L
