Old 10-28-2010, 08:01 AM   #1
ajserra
Shift detent
My column shift TH350 has a very slopppy feel when going from reverse to neutral to Dr 1 or 2 . It stays in gear, but you have to feel for the slot to put the lever in. I think that there should be a positive detent when you select a gear with the shift lever. Is something worn in my steering column or in the trans ? Is this an "easy" fix or a big (Expensive) job.
ajserra is offline   Reply With Quote
Old 10-28-2010, 10:21 AM   #2
70 net440
Junior Member
70 net440's Avatar
Re: Shift detent
There is a spring in the trans that rides on the rooster comb. I have seen these break before. Pretty easy fix, just need to drop the pan and remove one bolt.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 10-28-2010, 01:06 PM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Shift detent
It could be the spring that 70 net440 has described to you, but I suspect worn out, or incomplete shift linkage seeing how you can feel the transmission detents. I would check the linkage parts for grooves and slots before I dropped the pan. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 10-28-2010, 04:26 PM   #4
ajserra
Re: Shift detent
Thanks guys. I'll check these possibilities out.
Old 10-28-2010, 09:15 PM   #5
raycow
Re: Shift detent
For a quick check, disconnect the linkage at the transmission end and rotate the transmission arm by hand. This will tell you in a hurry where the problem is.
raycow is offline   Reply With Quote
