Old 10-28-2010, 08:25 PM   #1
JayE72
Speedojunk
1972 Chevy SB 350/350. Can the speedometer be repaired/rebuilt or is replacement the only option? The speedometer is jumpy. I just installed a new speed cable. Also who sells the least expensive printed circuit board for the dash cluster? Thank you for you help and insight!
JayE72 is offline   Reply With Quote
Old 10-28-2010, 08:36 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Speedojunk
Are you sure the gear in the trans is good? You can chuck up the old cable in a drill to check the operation of the speedo head.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 10-28-2010, 09:49 PM   #3
raycow
Re: Speedojunk
Most cities will have a speedometer shop that can repair these units. Check your yellow pages first and if you don't find one, look online. However, as already suggested, try turning the cable with an electric drill before you start tearing the dash apart.
Ray
raycow is offline   Reply With Quote
Old 10-29-2010, 05:40 PM   #4
JayE72
Re: Speedojunk
Thanks guys! I will give it a try.
