Low Hump in a 4x4?
Anyone done it? Is it possible? I'm thinking it might be possible with a body lift but not sure. Anyone have any insight on this for me?
'70 K10-- 4" lift on 35"s-- For Sale http://www.ksl.com/index.php?sid=733...iew&ad=4578305 |
Collector of Projects
Re: Low Hump in a 4x4?
Body lift would definitely sovle the clearance issue.... not sure how much higher the hump is... ORD makes a 1" lift kit out of aluminim. That might be all you would need.
http://offroaddesign.com/catalog/oneinchlift.htm |
What transmission?I assume automatic.I've converted low-hump to high-hump.I like the ease of access.I never considered what you are,but wonder about the transfer case shifter location and action.
![]() Join Date: May 2006
When I converted my 2WD to 4wd I had to raise the body 1 inch to clear the transmission (turbo 350).
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
Well I crawled up under the truck to see what kind of clearance..... I don't know why the previous owner put a high hump in it? It has PLENTY of clearance from everything. He only cut out a small section of the original low hump and then bolted the high hump in. I think it was to clear the floor shifter that's in there. It's the only thing I can even see that would cause interference. It's a turbo-350 and a 205 transfer case. I'm going to a low hump when I do my floor pans.
