10-29-2010, 04:08 PM | #1 |
Pics of 67-72s on air w/o notch
A quick search yielded no results of what i am looking for. I need pics of 67-72 swb fleetsides on air ride with no c-notch, just bags in place of coils. Preferrably with 18-20 combo or 20's all the way around. Please include wheel and tire info as well as air ride setup. Thank you and I would really appreciate it.
1970 c/10 swb (show truck) 1972 custom/10 deluxe 4x4 (restoration pending) 2011 silverado ecsb z71 (daily driver) |
10-30-2010, 04:16 PM | #2 |
67cheby
Re: Pics of 67-72s on air w/o notch
just bags with 20's
10-30-2010, 04:28 PM | #3 |
VA72C10
You sure you had no notch at all in the rear with that picture???
a lot of that is going to hinge on overall tire height as well. Here is a 72 longbed on 17's with a "hat" on the rear bag. it's about an inch from hitting the frame rails w/out the notch.
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 10-30-2010 at 04:35 PM. |
10-30-2010, 04:53 PM | #4 |
67cheby
no notch , but no hat on the bags just a plate
10-30-2010, 04:56 PM | #5 |
67cheby
the second pic in that last set was the same exact day as the first pic i posted i think the rear tires were 275-45-20??? i think that might not be correct
10-30-2010, 04:58 PM | #6 |
VA72C10
cool. Looks lower than I thought it would have been. I guess that's when it's sitting right on the frame basically? ( i know you're a "little" lower now )
Looking for a 67-72 swb or blazer project in or around VA. |
10-30-2010, 05:02 PM | #7 |
67cheby
it was actually setting on the u-bolts !! and yes i am a tad bit lower now.....and if i would have stopped then i would have been driving this for the last year !!
10-31-2010, 12:26 AM | #8 |
Here is my truck no notch the rear bags are located in the factory spring location. I have 18" wheels on a tire about 28" tall.
Now my two cents... once you get the air bag bug you will never be low enuff and hope to notch mine this winter
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
11-01-2010, 10:46 AM | #9 |
Thanks very much guys for your input. Cheby I love watching your build progress, it's come quite a long ways since you took those pics! Thanks VA for reminding me about the hats on the rear. I'm going to do what Cheby did and drill the frame. Also on the front I will be cutting the cups on the front brackets, I cant remember now what your supposed to cut them down to though. Firedog your truck is beautiful! Do you have a build thread or more pictures? As far as never being low enough.....A man can only go as low as his budget allows, and for me that aint much. Also Firedog your front end seems way low, you still runnin inner fenders? Thanks again guys for your help!
11-01-2010, 05:51 PM | #10 |
Not all cups on the front NEED to be cut, but the goal is to get the cup to sit flush with the arm.
This was my '69 with no notch in the rear aired out (front has cut cups and drop spindles)
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 11-01-2010 at 05:52 PM. |
11-03-2010, 08:24 PM | #11 |
thanks for the compliments, there is a thread on here from when i put bags on my truck 2 years ago, the front is without inner fenders and i have chisolm lower control arms with a 2" drop pocket built into them and customized to mount the bags in them, i am not sure which bags i have in the front but they are not very big around and fit completely in the spring pocket along with 3" drop spindles
