10-29-2010, 05:23 PM | #1 |
good cam choice?
So I was originally going to build up my 307 but I had a 350 laying around and tore it down, it just needs new main bearings and piston rings. it is a stock bore and will stay that way stock 76cc heads. flotech headers with cherry bomb glass packs. the tranny is an sm465 with an Eaton ho52 rear end, unsure of ratio at this time. I have an edelbrock 600cfm carb and a weiand intake both 4 bbl. my question is what would be the best cam to go with? I currently have a 280h comp cam and I know it will be way to much for a daily driver but that's what was in the 350 when i bought it. the cams I am looking at are from summit. this is going into a 1969 c20 lwb
Summit Racing SUM-K1103 http://www.summitracing.com/parts/SUM-K1101/ SUM-K1100 http://www.summitracing.com/parts/SUM-K1100/ summit 1101 cam http://www.summitracing.com/parts/SUM-K1101/ I guess an easier question would be I want a slightly lumpy idle without killing my gas mileage in the truck. I dont know if its possible or not with my current setup but I would LOVE to be at around 330hp if its even possible with the stuff I have. I would like to only spend around $130 or so for the cam and lifter kit as well thats why summit appealed to me to much. thanks for the input and help.
1969 C20 3/4 ΜΟΛΩΝ ΛΑΒΕ |
10-29-2010, 07:12 PM | #2 |
Re: good cam choice?
any one? any help would be greatly appreciated.
10-29-2010, 07:34 PM | #3 |
Between Trucks...
I had good luck with this grind in a fairly stock 350.
http://www.summitracing.com/parts/SUM-1102/
Beat it to fit, Paint it to match... |
10-30-2010, 07:56 AM | #4 |
I was runing an edelbrock 7102
RPM RANGE: 1500-6500 Duration at 0.006" Lift: Intake: 308° Exhaust: 318° Duration at 0.050" Lift: Intake: 234° Exhaust: 244° Lift at Cam: Intake: 0.325" Exhaust: 0.340" Lift at Valve: Intake: 0.488" Exhaust: 0.510" Timing at 0.050" lift: Open Close Intake: 10° BTDC 44° ABDC Exhaust: 59° BBDC 5° ATDC Centerlines: Lobe Separation - 112° Intake Centerline - 107° a fue years ago when gas was over $4.00 a gal I changed to a comp 268h 1,500-5,500 Intake Duration at 050 inch Lift 218 Exhaust Duration at 050 inch Lift 218 Duration at 050 inch Lift 218 int./218 exh. Advertised Intake Duration 268 Advertised Exhaust Duration 268 Advertised Duration 268 int./268 exh. Intake Valve Lift with Factory Rocker Arm Ratio 0.454 in. Exhaust Valve Lift with Factory Rocker Arm Ratio 0.454 in. Valve Lift with Factory Rocker Arm Ratio 0.454 int./0.454 exh I lost alot of top end power but it pulls better from 1500 to 3500 a little rumble at idle and about 4 mpg better |
10-30-2010, 08:10 AM | #5 |
best advise you can get is by calling a few different cam company tech lines with all your specs and expectations and ask them for a recomendation for cam lifter and spring package
10-30-2010, 10:50 AM | #6 |
Tech company is the way to go, but you have to decide low end torque or high end power. Street, MPG, show, sound, towing, crawling or a little of everything.
1971 Chevy C-20 Flatbed SBC350/Turbo 350 "Torque Is Controlled Power" |
10-30-2010, 01:34 PM | #7 | |
With my build i called Comp Cams and they recomended Grind # CS 260H-10
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 10-30-2010 at 01:39 PM. |
