Old 10-30-2010, 12:29 AM   #1
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
5.5/7inch combo static drop questions
I ordered my CPP grand slam without thinking to ask what rim size I should run 18 or 20's do not want different front and rear unless it's just a width difference and what size tires to put on them to ensure I'm not too close to the ground where I'm gonna be scraping everytime I drive it, also will this make for inner fender issues? any pics of this type of drop with info on rim and tires you're running would be a HUGE helper for me as well, guess I got excited a bit to be ordering and rushed into it
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 10-30-2010, 08:40 AM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: 5.5/7inch combo static drop questions
Check in raguemoe... his '67 is amazing running 20/22's (IIRC) and a 5.5/7
Search his past posts for more info/pics:
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-30-2010, 08:50 AM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Check out this thread... it's for his other truck, but contains info about his white '67.
http://67-72chevytrucks.com/vboard/s...d.php?t=245772
-Nate
Old 10-30-2010, 08:45 PM   #4
tantrumpipeline
looks perfect, thanks a million for the reply, starting to think I was in trouble with this one, his post says enough for me, I'll be all good, settled on the 20x8.5 338's and going to run a spacer in the back to push them out to avoid issues with rotating etc, thinking of a 255/45zr20 tires just to give me a little more clearance, the roads here are terrible here but that stance is exactly what I'm after, the rough/corvette style ride may be a little bad for here, but I'll stick with CPP just on the dealings I've had with Jeff so far, thanks again
20 Duramax tow pig
52 short project
