Truck/Suburban frame interchageability?
I want to build a flatbed square body for a shop truck. It was going to be my '79 C30 but I would need to swap in an auto trans and the cab floor/rockers/doors are rusted out. I think I may just part this truck out and find another truck with the drivetrain I want. 4WD and a big block would be nice too...
Anyway, around here an '80s 4x4 loaded Suburban is much cheaper and easier to find than the same in a truck. If I find a 'burb with a drivetrain I like, can I remove the body and bolt on a regular truck cab and build a custom flatbed from there? I want to find a 73/74 cab for emissions reasons. Can I add to that monster my entire '79 front clip? Will that work on an 80s suburban frame? I would also like to keep the suburban doors which are more likely to be power everything than a 70s truck. And I want the rear gas tank. Also, just how much work is involved in putting a 2WD cab on a 4WD chassis? Can I just cut a big hole and patch over it later hillbilly style? I'd like to find a 4WD cab, but, if it's a 73/74 I'll take what I can find.Obviously I "can" do just about anything I want, but I'm looking for mostly a bolt together project.
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's. You can set my truck on fire and roll it down a hill, and I still wouldn't trade it for a Coupe de Ville. |
Arrived on a Pale Horse
Re: Truck/Suburban frame interchageability?
You may have to put on a 3 inch body lift. 4WD cabs have a taller "hump" in the floor to accomodate the transfer case.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
Still plays with trucks
Or he could just bolt in a high hump removable tunnel. The rest of the cab is the same.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
Robert Olson Transport
![]() Join Date: Oct 2002
youll have to modify the burb frame to accomodate the back of the cab and dont forget burb frames are wider than pickup ones... i found this out the hard way with a trailer hitch
#5 | |
The curves of the Suburban frame are different from a truck behind the front cab mount so it may take a little playing around to build some rear cab mounts that will fit. The truck frame curves upward a few inches while the Suburban frame stays somewhat level. The 80's Suburban high hump transmission tunnel may be integral with the floor and not be removable like the older ones are. I know the newer square bodies I have seen they were integral. I just don't know what year they made the change or if it was just option specific. You may have to locate a bolt-in type high hump transmission tunnel to put in it for transfer case clearance but otherwise the rest of the truck cab is identical 2wd vs 4x4. Look for a 2wd half ton truck with A/C. It will make the Suburban parts swap easier and your insurance rates & registration costs will be lower too.
I thought the frame rail width was the same out back at ~34". That is good to know that they are different.
Any more info on this? I think the Suburban is 2 inches longer? right? Other than the mounts in some different places and a flat frame, has anyone mounted a pick-up body on a Suburban frame???????????? The reason why I'm asking is in my signature below. That 89 is a really nice chassis for my 85 extended cab conversion to 3/4T without destroying my 83 3/4T in the process. If it can be done, I'll give it a try...........
David
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
Alright...last chance to tell me I'm crazy...
![]() I found a loaded 1991 burb 1/2 ton 4x4 with a 454 for $800, bad trans. Still talking to a guy about a '73 C10 rolling chassis/cab for $400. Can gut my '79 for front end and a 14 bolt rear axle. Find a cheap TH400.... Sound like a recipe for a '79 suburban flatbed with the rare "emissions free" option?
78K & 79C Jimmys
sounds like a plan!
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
I just wanted to say thank you for the info on the swap. I'm going to be doing the same swap in a couple of months. I already own a '74 C-10, and my friend has a '90 Suburban 4x4 with a 700R4/NP208 setup in it. I'll post pics when we get around to doing the swap. Again, thank you for the info.
frame is the same width the only frame width diff in those trucks maybe be in a cab an chassis truck or a ton truck
But Found Her 25yrs Later!
I've read in some places that the frame is more flat on the suburban. It doesn't kick up as high after the cab like the pickup frame. Can anyone confirm?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
| Bookmarks |
