10-30-2010, 02:06 PM | #1 |
A-arm shaft bushings available?
I'm doing a front end rebuild kit on my 72, which is basically all the bushings and tie rod components, but all I have seen available for the A-arm shafts is to replace the shaft itself. Does anyone make a bushing kit for these that just replaces the bushings and retains the stock shaft, or does it all have to go? It looks like everyone carries the replacement shafts, but I haven't seen just the bushings. Figured I'd save a couple bucks if I didn't have to replace the entire shaft just to refresh the rubber. Thanks in advance guys.
Derek 72 Chevy Cheyenne Super LWB 454 SS LS6 90 GMC Suburban V2500 350 ----------- 64 Chevy El Camino 357 73 Jeep Wagoneer 360 78 Jeep Cherokee 360 79 Scout II 345 88 Jeep Wrangler 4.2L 91 Jeep Wrangler 4.3L 98 Lincoln Mark VIII 4.6L 01 GMC Yukon 5.3L "If it's not broken, fix it 'till it is!" |
10-30-2010, 02:49 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: A-arm shaft bushings available?
I was told by several knowledgeable folks to replace the a-arm shaft and all, because the original shaft can be brittle or more brittle than what is safe, a new shaft will be made with current specs and hardness which is far superior than 40+ years ago.
Also I couldnt find any bushings either, looked at many vendors on line and locally.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-30-2010, 02:53 PM | #3 |
I can definitely see the benefits of replacing the whole shafts. Looks like that might be the route I end up having to go. I haven't even pulled the front end apart yet, so the old ones may be just fine, it was just going to be the best time to replace anything that might need it. Probably go ahead and order a set from ECE I suppose.
10-30-2010, 03:03 PM | #4 |
Six in a row makes it go...
Do your A-arm shafts even have any rubber in them? My '67 C20, my brother's '68 C10, and my other brother's '71 C10 are all steel-on-steel.
Do you have a later model front suspension?
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
10-30-2010, 03:10 PM | #5 | |
Here are the ones that Classic carries: http://www.classicindustries.com/tru...ts/13167a.html http://www.classicindustries.com/tru...ts/13168a.html Those are considerably cheaper than what I've seen elsewhere. They are about half of what ECE charges and less than CPP as well.
10-30-2010, 03:22 PM | #6 |
Project Junkie! Fishing Poor!!
Probably not great quality either. You get what you pay for. I don't mess around with cheap parts on front ends. You can go to your nearest NAPA and buy good Moog parts. They probably even have them on the shelf. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
10-30-2010, 03:23 PM | #7 |
So true.
10-30-2010, 03:28 PM | #8 |
Burnouts are therapeutic
they do not have rubber on them, I just took mine apart yesterday they are metal on metal. I "believe" they started using rubber bushings in 73 on trucks. deffinently replacing mine with moog. good luck
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
10-30-2010, 04:49 PM | #9 |
just saw some in a magazine. p-s-t.com never dealt with them
10-30-2010, 05:17 PM | #10 | |
http://www.classicperform.com/Store/...ruck/FA538.htm Just trying to clarify...
10-30-2010, 05:43 PM | #11 |
While shopping around to see if the local stores carried them, I found them at O'Reillys. They carry the Master Pro Chassis one:
http://www.oreillyauto.com/site/c/de...0318&ppt=C0106 And the Moog one: http://www.oreillyauto.com/site/c/de...0318&ppt=C0106 Both are lifetime warranties, but they are the same part number! Nowhere near the same price though, the Moogs are double the price. I wonder what the deal is with that...
10-30-2010, 05:47 PM | #12 | |
10-30-2010, 06:44 PM | #13 |
Moogs available on Amazon.com for $41.82 upper and $33.97 lower with free shipping. Part numbers K6098 and K6147. Just an fyi...
10-30-2010, 07:37 PM | #14 |
that rubber is a dust shield or something, it does not go between the endcaps and the a arm. if you look at the pic in the link you posted to CPP the part of the endcap that looks threaded goes into the a-arm, you'll see it when you take it apart it's not that complex. good luck
10-30-2010, 07:40 PM | #15 | |
Gotcha, I think I see what you're saying. I went ahead and ordered a set of Moogs, so I'll get those and the rest of the front end rebuild tackled soon hopefully. And drop springs, of course
10-31-2010, 06:47 AM | #16 |
The bushings are threaded on the inside and the shafts are threaded too. The threads wear on both parts in normal use and that is why they are sold together as sets.
Unless you are doing a stock resto, you might want to consider replacing the control arms and shafts with the 73-up type. These use rubber bushings which can be easily replaced when required and also eliminate the need for greasing. Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
10-31-2010, 10:45 AM | #17 |
Do you have any more info about that swap that I can read over or anything? That's the first I've heard about using later model control arms (sorry, I'm still new here...)
10-31-2010, 02:24 PM | #18 | |
I believe all the details are covered in this rather long disc brake swap thread. http://67-72chevytrucks.com/vboard/s...ght=disc+brake Ray
10-31-2010, 02:33 PM | #19 | |
