Old 10-30-2010, 03:27 PM   #1
buttrock slp ss
buttrock slp ss's Avatar
12 bolt 6 lug to 5 lug straight swap?
i have a 69 c10 thats 6 lug drums all around i bought a parts truck that has disc brakes and its 5 lug i was curious if the 5 lug axles that are in the parts trucks 12 bolt i can use in my current 12 bolt that has 6 lug axles in it? i have not done much research yet just curious. thanks for any input.
buttrock slp ss is offline   Reply With Quote
Old 10-30-2010, 03:30 PM   #2
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Re: 12 bolt 6 lug to 5 lug straight swap?
I believe the 5-lug rearends are wider and the axles will not interchange, There are aftermarket axles that will fit and are made for this conversion, maybe you could even have your axles redrilled to 5-lug pattern ....
ksbrktracer is offline   Reply With Quote
Old 10-30-2010, 03:36 PM   #3
buttrock slp ss
thanks, yeah i figured something was probably diff like that. I have seen the 5 lug conversion axles on like classic performance parts.com and stuff but they didn't list any dimensions or anything vs a 6 lug axle.
Old 10-30-2010, 04:38 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
67-69 are one size and later 69-72 are the wider width....not 100% sure the axles interchange, but there are 70 6 lug rears that are the same width as 71-72's with 5 lugs..
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-30-2010, 07:04 PM   #5
ERASER5
ERASER5's Avatar
Do not re-drill the axles. The holes will over lap, no way around it.
Swap the whole differential from your parts truck, or, if you have a certain ratio, or posi already, get after market 5 lug axles.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-30-2010, 08:30 PM   #6
corvetteman10
I am doing the same swap but i am going to use the complete 5 lug rear end. Is there a reason why you cant use yours?
'72 cheyenne10 tilt, tach, a/c, posi
'70 custom10- daily grind
corvetteman10 is offline   Reply With Quote
Old 10-30-2010, 09:02 PM   #7
ksbrktracer
TNT-MOTORSPORTS
personally I am gonna run the narrower axle so I can run a deeper wheel
Old 10-30-2010, 10:30 PM   #8
ERASER5
ERASER5's Avatar
Excellent plan. If you are already going to run different rims front and rear, by all means, a slightly narrower rear should work to your advantage.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 10-30-2010, 11:22 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the narrower rear won't net you any more room. The space for the tire is the limiting factor.
As stated, the axle shafts will not properly swap. Some will tell you to do it with wider drums, and some will tell you there's has gone 7 years with no issues. But it is an unsafe modification.
Swap out the whole rear end.
Old 10-31-2010, 12:21 AM   #10
65Guy
Oh yea.... I just took the back tires off my truck and someone before me put the longer axles in my truck. The drums only ride on about half the pad. Not very safe....
65Guy is offline   Reply With Quote
Old 10-31-2010, 12:37 AM   #11
buttrock slp ss
thanks every one its no big deal im gonna do mini tubs at some point that will net me some extra space, but the main reason i wanted to kinda skid by is i have a factory option posi unit in my truck. I have not taken the diff cover off or simply jacked up the rear diff and spun the tires on the parts truck yet. Its good to know the different widths in years thanks guys. Depending on the out come ill probably just buy a pair of after market axles. $289 for 2 new 5 lug axles isnt too bad, then ill just use 71-72 drums and i will be golden if the other unit is not a posi. btw the truck is a 68 its a roller with 6 rubber maid tubs of parts lol. its a short bed step side with a disc brakes up front, i dont trust the booster and prop valve where swapped from the disc brake truck they used so im gonna get new ones of thoose as well as a 71-72 brake pedal to booster rod.
Old 10-31-2010, 12:41 AM   #12
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
CPP makes a kit for our trucks ordering one monday, talk to jeff we get 10% off forbeing board members, he's a deadly guy to deal with and shipping is quickhttp://www.classicperform.com/Store/...k/6569RACK.htm
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 10-31-2010, 12:51 AM   #13
buttrock slp ss
awesome thats who im gonna go through thanks for the info bro!
Old 10-31-2010, 12:58 AM   #14
tantrumpipeline
for sure, I'm having great luck with these guys, got cpp tranny x member, c notches, grand slam kit(5.5in frt 7in rear drop, disc brake and booster setup, front end rebuild), trailing arm rebuild kit, poly body mounts, all on order from them just on the way the dealings have gone, everyones different but I've had great luck with them abd the 10% off is nice for sure
20 Duramax tow pig
52 short project
Old 10-31-2010, 09:56 AM   #15
mrhino
I'v done 3 rear disc conversions now and honestly best way Iv found so far is Moser Engineering.. So Keep your rear end and get a set of Moser axles they have them already made for your rear end with 5 lugs, or they will custom make a set any way you want.
heres a link http://www.moserengineering.com/axle...spline-30.html
mrhino is offline   Reply With Quote
Old 10-31-2010, 09:15 PM   #16
tantrumpipeline
don't know much about CPP as far as tough goes, but when I was into rockcrawling, mosers are very very tough, may wanna go that route, I'm not going to have the HP for any problems
20 Duramax tow pig
52 short project
Old 03-15-2012, 10:43 PM   #17
npoe2982
this is good info i was just going to swap axles from a 72 to a 67 rear end glad i wont waste time. new to the forum i appreciate all the tips
npoe2982 is offline   Reply With Quote
Old 03-15-2012, 11:20 PM   #18
tantrumpipeline
the 72 is a wider axle but that's an easy swap as well
20 Duramax tow pig
52 short project
Old 03-16-2012, 12:37 AM   #19
AustinScott
AustinScott's Avatar
All images are provided by performanceonline.com and used only as reference.
12bolt 5 lug conversion axle 1965-1969
12bolt 5 lug conversion axle 1970
Performaceonline has what you need if you want to make the swap & don't end up using the axles you have.
By the way, I was told that you could use the axles you have in the 67-69 "short" housing, but you just have to get the wide rear brake shoes so the will engage more than 9o% of their width to the drum.
-=scott=-
AustinScott is offline   Reply With Quote
Old 03-16-2012, 05:31 PM   #20
npoe2982
i just picked up a 12 bolt from a 72 seems like its in good shape. just going to swap the whole thing. not sure what the ratio is yet but that should of no real consequence i should still be able to use the guts from my 67 if i prefer. i think i can even use the wheel cylinders but not sure.
Old 03-16-2012, 05:40 PM   #21
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
I am another Moser satisfied customer
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 03-16-2012, 05:47 PM   #22
chevytruckluver
from Texas
You can use the guts from the 67 rear in a 72 housing but you better know what you are doing. setting up gears requires a dial indicator, at the very least you will need a new crush sleeve on the pinion, even if you are able to use the same spacers.
Trey
72 Short Step
Old 03-16-2012, 08:14 PM   #23
1stchevy
1stchevy's Avatar
I ordered mine from Early Classic Enterprises and the axles they sent were from Dutchman Motorsports. Nice looking stuff no issues, as I'm sure Moser would be the same way.
1stchevy is offline   Reply With Quote
Old 03-16-2012, 09:18 PM   #24
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Portland in da house! They setup a 9" for me for my '68 Camaro.
prostreetC-10 is offline   Reply With Quote
Old 03-17-2012, 01:10 AM   #25
npoe2982
i could possibly strap a log to the control arms and fashion some stone wheels and get by but i should probably know what i doing before hand. do you think i might need a dial indicator?
