Old 10-30-2010, 06:05 PM   #1
raider65
raider65's Avatar
Bolt size
I plan on switching out PO's headers to the original ram horns in a couple of months. I am collecting the parts that i need. My question is what size bolts am i going to need to mount them. I know they are 3/8 x 16 but what lengths do i need . I know the center ones are longer than the four outside bolts. I plan on using grade 8 bolts am i correct on that?
It's not rust...It's character!
raider65 is offline   Reply With Quote
Old 10-30-2010, 06:06 PM   #2
stich626
Re: Bolt size
I'd use s/s
stich626 is offline   Reply With Quote
Old 10-30-2010, 06:30 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Bolt size
I don't remember the lengths but you want 1 and a half time the bolt diameter to screw into the head. So about 1/2 to 9/16". Measure the manifold add 1/8 for an SAE flat washer not an USS and add the 9/16"
dwcsr is offline   Reply With Quote
Old 10-30-2010, 08:27 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Bolt size
You can get the original bolts at the salvage yard if you want the originals. Don't forget the heat shields & locking tabs.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
