10-30-2010, 06:51 PM | #1 |
Cab mount tube length
I am new to the sight and wanted to know the length of the tubes that go through the rubber mounts for a 67 cab. I ordered a set from Brothers and no tubes came with them, I called Brothers but got no help.
10-31-2010, 06:59 PM | #2 |
Re: Cab mount tube length
bump
10-31-2010, 07:25 PM | #3 |
2 wd or 4 wd?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
10-31-2010, 08:45 PM | #4 |
2wd
11-05-2010, 10:07 AM | #5 |
Why is it you guys can answere all the questions about spark plugs - 20" wheels and lowering your trucks but when this newbie asks a legitimate question he gets no answere and there have been 7 pages of stuff since he asked. Surely someone out of the hundreds on this site has a set of 1/2 ton cab mounts they can stick a tape measure on the tubes. My truck is 3/4 ton so I'm unable to get a measurement. Pardon the rant ---- go back to talking about buddy buckets or spark plugs.
Bob in Pa |
11-05-2010, 10:46 AM | #6 |
I had the same problem. No tubes. Instead of trying to track them down from where I bought the mounts, I went to Ace Hardware and bought some tubes in the hardware section and cut them to the length of the original rusted tube. A few caveats: you still have the original tube, the 67 (I have a 72) uses a tube that is the same diameter as what you can find at a hardware store. Hope this helps. I can try to get a measurement of the length needed when I get home.
11-05-2010, 10:51 AM | #7 |
There was nothing left of my tubes to measure
11-05-2010, 01:01 PM | #8 | |
Project Junkie! Fishing Poor!!
1/2ton 2x4s are 2 1/4" long 1/2ton, 3/4 ton and 4x4s are front 2 1/4" and the rears are 5". WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
11-05-2010, 01:06 PM | #9 |
454 MAKES IT ROAR
When you posted I had just done mine and thrown the old rusted ones out, so frustratingly unable to help ya. I would say that from memory the sleeves ran the length of the rubber mounts when assembled, so if you already have new rubber mounts minus the metal sleeves, just fit them together and measure the length....Just a thought, you may need to cut them maybe a 1/2" shorter to allow for compression when you install and tighten the long bolts up.
Here's a pic of the old set it shows the sleeve on one, maybe while you have your new one's to hand you could work out how long this is considering how much is on show top & bottom of the rubber mount. Maybe 2 1/2"?
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 11-05-2010 at 01:09 PM. |
11-05-2010, 01:37 PM | #10 |
Thanks for the reply, sorry about the lack of information, I wasn't thinking . I knew 1/2 and 3/4 were different but didn't think about 4x4.
11-05-2010, 01:50 PM | #11 |
Under Construction
yeah the only bad thing about brothers is they sell the kit without the spacers (tube)
Our kit is absolutely correct as original. The bushings are made exactly like GM and includes the correct hardware also. Note these do not come with spacers. Looks like WES helped you out above on the measurements. if you cant find them locally contact WES and he should be able to help you out. you can check out his site at classicheartbeat.com , it is alway good to support board vendors....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 11-05-2010 at 02:13 PM. |
11-05-2010, 02:06 PM | #12 | |
RAT1968 '68 Cab/'71 Parts
And I *really* appreciate an answer to one of my (many) inquiries when it comes as a known fact from a Forum Member. So, I don't offer up an answer unless I know, for sure, that I'd be helping. As far as this specific question, most folks probably have limited access to this part because their beds are already bolted down. And, like me, maybe most are not *exactly sure* if there would be a difference between, say, a '67 C10 or 20 and a '71....... Posted via Mobile Device
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
