Rochester Carb Issue
I have a Rochester 1BBL on my 64 inline six and the when I pull the choke lever the the shaft moves but the choke butterfly doesn't it just freely hangs. I rebuilt the carb several weeks ago and it was doing great but today I was having starting issues and believe this is the problem. I've search the interwebs high and low and can't find the shaft assembly, is my carb done and I need a new one or is this replaceable?
Re: Rochester Carb Issue
Sounds as if you lost the plate screws at one time, see this link
http://www.sportcompactonly.com/manu...s/199R9978.pdf fiqure # 10 just for visual purpose.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#3 | |
Then the cable must be sliding thru the lever link or the lever itself is ( I believe is been stamped on the shaft ) and is loosened up and rotating on the shaft, If thats the case you`ll have to remove the plates pull the shaft out and restamp it if possible, or what I have done in the past is if the shaft and lever not to rounded off is to drill out the center of the shaft and tap it and use a machine screw to lock the lever down with a washer and lock ring. the shaft being brass will drill and tap very easily....
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip Last edited by Rich 5150 69; 10-30-2010 at 09:08 PM. |
#5 | |
IIRC, the lever that the inner cable attaches to is not part of the shaft. There is a coil spring wound around the shaft that connects the two parts together. So if the spring is missing, broken, or unhooked, pulling the cable won't rotate the shaft.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. Last edited by raycow; 10-31-2010 at 04:57 AM. |
