Old 10-30-2010, 10:28 PM   #1
ryans69chevy
Something seems wrong...
I got a 69 chevy c10 and I use it to drive 25 miles one way to college everyday. I installed a tach that I bought from harbor freight for $20. When I drive I go about 63 mph because the tach reads just under 5000 rpms! The engine is pretty noisy going that fast. I'm just wondering if there is anything wrong with my truck or if it's just a cheap tach. I couldn't imagine a tach being that far off. It seems like everyone else that has something around my set up revs around 2200-2500 rpms... The truck has got a 307 muncie 4 speed and 3:08 gears in the rear end. I know it has 3:08's because I took the cover off and counted the ring and pinion myself and divided. Any ideas what's going on?
ryans69chevy is offline   Reply With Quote
Old 10-30-2010, 10:35 PM   #2
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Something seems wrong...
does the tach have the switch on it were you switch for 4 cyl. 6cyl or 8cyl? and its in the wrong position? just a thought.............
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 10-30-2010, 10:37 PM   #3
LandonL
LandonL's Avatar
On the back of the tach I bought, there were settings for 4 cylinder, 6 cylinder and 8 cylinder. See if the one you bought has one, it should be on the back. The other problem may be it came from Harbor Freight. Thats the best I can do, if this doesn't solve it I hope someone else can! Good luck!
EDIT: Hubscrub beat me too it! Haha.
---| 1967 GMC Stepside |--
250 L6 .030 over
---| 1985 Porsche 944/1 |---
Build Thread: '67 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=378640
LandonL is offline   Reply With Quote
Old 10-30-2010, 10:40 PM   #4
cheepin
Think your tach is a piece or the setting is wrong on the back.Assuming and 29" tire your should be running just over 2200 rpm.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 10-30-2010, 10:41 PM   #5
71swb4x4
71swb4x4's Avatar
Just because something is new, doesn't mean it works correctly. Check out what the first two people suggest, if that doesn't work return it for a new one.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-30-2010, 10:44 PM   #6
ryans69chevy
haha ya you guys are both right. I actually just checked before I reposted and the switch was and is on the v8 position. I thought it was just because it's harbor freight S#@T, but I just can't imagine a product being THAT far off. The engine is VERY noisy going that fast too.
Old 10-30-2010, 10:47 PM   #7
ryans69chevy
I bought it awhile ago...like last spring probably. I'm actually bringing my truck down to brookings to visit my friend at college!
Old 10-30-2010, 11:25 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
I have one of those in my Green '67 and even though the needle is not real steady it seems to be pretty accurate. I can't see how you could be turning that many rpm with the setup you have. Yes, the engine might be noisy at 63 mph but I can't believe 5000 rpm worth....
LockDoc
Leon
Old 10-30-2010, 11:59 PM   #9
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
dang does it sound like 5k lol!! 5k i couldnt drive @ that much rpm for long!!! LOL
John
1999 Toyota Tacoma 4x4
Old 10-31-2010, 07:10 AM   #10
raycow
Since nobody else asked, what kind of ignition setup do you have? Some tachs made for points do not work right with HEI, and sometimes the reverse is true also.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 10-31-2010, 09:42 PM   #11
ryans69chevy
I guess I'm not really sure what ignition system I have...I haven't changed anything on it. So I'm assuming it's stock. Whatever type of system that is. What's the difference in types?
Old 10-31-2010, 10:23 PM   #12
oldblue1968chevy
if its unchanged from the factory its the old points style
newer is HEI
John
Old 10-31-2010, 10:30 PM   #13
raycow
The original ignition system in 1969 used a set of contact points that are opened and closed by a cam on the distributor shaft. If you take off the cap and rotor you will be able to see if you still have them.
HEI and other types of electronic ignition replace the points with a magnetic sensor. The problem is that the two types of systems generate a signal that the tach "sees" differently. Most modern tachs will work on either type of system without a problem, but a few of them won't.
Ray
Old 10-31-2010, 10:35 PM   #14
ryans69chevy
Ray
Ya I'm sure it has the points then, because I haven't touched the ignition system. So is there another way to hook up a tach if it has those contact points to make it work? Or is the tach just not able to work period in my system?
Old 10-31-2010, 10:56 PM   #15
LockDoc
LockDoc's Avatar
Mine has the stock points dist. with no problem...
LockDoc
Leon
Old 11-01-2010, 12:01 AM   #16
Stocker
20' Daredevil (Ret)
Stocker's Avatar
My Sun tach worked with the OEM points ignition, and it works with HEI. It's starting to sound like your HF tach may be defective. However, with 3.08 gears, your engine should not be that 'noisy'. I wonder what noise you are hearing, though. Does it have a fixed fan? Those pull a lot of air and make a noticeable roar at anything much over idle speed.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-01-2010, 12:30 AM   #17
raycow
Since someone must have done a transmission swap in order for you to have that Muncie, could it possibly have the wrong speedo drive gears in it?
Ray
Old 11-01-2010, 02:04 AM   #18
El Jay
Gone to greener pastures
Are you sure you have 3.08:1 rear gears? It's the noise thing that makes me ask.
Both my 1/2 T. Chevy & 3/4 T GMC have 4:10:1 gears and they only turn about 3000 RPM at 65 MPH.
Also, FWIW, they both have aftermarket tachs; the Chevy has electronic ignition & the GMC still has points & condenser (but not for much longer!).
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 11-01-2010, 01:19 PM   #19
ryans69chevy
Ray
Well I'm fairly certain it has a Muncie. What did they come with? Or how would I tell if I have anything different than a Muncie? If there was a wrong speedo gear in it wouldn't that make the speedometer way off? I'm pretty sure my speedometer is very close to accurate...
Old 11-01-2010, 01:22 PM   #20
ryans69chevy
I'm positive I have 3:08's because after I did the equation I ended up with 3.07 and some more numbers. And I also picked one wheel up and after 2 spins the driveshaft made just over 3 turns. Maybe it has to do with my transmission. I start out in 2nd gear and switch to 3rd by 10mph and then end up in 4th at 25mph.
Old 11-01-2010, 01:41 PM   #21
Papaloo
Papaloo's Avatar
I know you said you have a C10, but is the truck 4wd? That's about where mine would shift if I had transfer case in 4Lo.
Dave
1971 Chevy K10
1972 Chevy C10
Papaloo is offline   Reply With Quote
Old 11-01-2010, 02:50 PM   #22
raycow
After reading your later post where you talk about starting in 2nd gear, I am pretty sure you have an SM465 which would have come stock in the truck. When most people talk about a "Muncie 4 speed" they mean a car type transmission. So this means your speedo gearing probably isn't at fault. At first, I was thinking you might have been going a lot faster than your speedo was showing, but not now.
Ray
Old 11-01-2010, 05:41 PM   #23
slomotion
Old Duffer
slomotion's Avatar
I probably missed it somewhere.....is this an eight or six cylinder engine?
Never mind, I see it.....307.
Sorry
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 11-01-2010, 06:36 PM   #24
292farmer
292farmer's Avatar
theirs no exhaust leak is their?
1972 gmc c25 292/sm465 dana 60 w/5.13s
1973 vw super beetle 1600cc/4spd(baja bug)
1974 chevy c60 351v6/np-540+2 speed eaton rear
2005 chevy cobalt 2.2l
292farmer is offline   Reply With Quote
Old 11-01-2010, 06:37 PM   #25
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Have you verified your actual speed with a GPS or by time between mile posts? Maybe you're running along at 95 or so, which would explain the truck being so noisy.
- Mike -
RIP El Jay
