4 speed help
So i am swaping out the automatic transmission for a 4 speed. The truck was once a 4 speed so the install is going well. I got all the original parts off a donor truck but have hit a snag. The rod connecting the pedal to the z-bar does not line up. It seems like the piece coming off the pedal assembly where the rod hooks needs to move over about an inch or two so that the rod will be able to travel through the hole and connect to the z bar. Any ideas why this may be?
1969 red k/10 with sb350 4.11 gear ratio, front disk, 3 speed automatic |
Re: 4 speed help
The obvious question first. Was the donor truck the same year as yours? If yes, would it help any if you flip the arm over where it clamps to the shaft?
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
Re: 4 speed help
Can you flip-flop the rod? Everything else should be in its spot.
Re: 4 speed help
No it was a 67 and a 2wd. Does that make a difference?
Re: 4 speed help
The rod is the same on both ends.
Back in the sticks
Re: 4 speed help
Is the rod straight or does it have a bend in it? Kind of like a little s-curve. At the end where it connects to the z-bar, there should be that kink to get it to line up with it.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Back in the sticks
Re: 4 speed help
Sorry for the crappy cell phone pic. Can't find my digicam.
