Old 10-31-2010, 01:19 PM   #1
matthew.doan
Question 51 chevy help
I got this 51 chevy 5window cab to use for a project because the cab is in great shape but the problem i have is that the bolts that hold the door hinge on are broke off!!!
How would I go about getting these out?? and the pass side looks like they have been cut with a plasma cutter or somthing?
Any help would be great!!
Thanks matt
matthew.doan is offline   Reply With Quote
Old 10-31-2010, 03:13 PM   #2
xpickup
xpickup's Avatar
Re: 51 chevy help
matthew.doan, If the bolts are broke off flush center punch the center of the bolts and drill the bolts out and retapp, if not grind flush the get a good start. I would start with a 1/8 (.125) bit first and then a Q drill bit (.332) the bolts are tapped for 3/8-24. The side that has been plasmed out you can buy the panel but you would have to make the part with the threads. Post a picture if you can to see best fix.
xpickup is offline   Reply With Quote
Old 10-31-2010, 08:34 PM   #3
chevy49
chevy49's Avatar
Re: 51 chevy help
can you weld a nut to the bolt on the inside of the nut?
chevy49 is offline   Reply With Quote
