Old 10-31-2010, 01:56 PM   #1
sharpie1972
Spring hangers. 4x4 and 2wd. Rubber bump stops.
Complete 2wd rear spring hanger set. 4 pieces. Excellent shape. $100 plus $14.50 large flat rate.
4x4 rear spring hangers. $35 each ($30 for the rear with no shackle). plus $10.70 medium flat rate. I will combine shipping the cheapest way possible if you want more than one. SOLD
4x4 front bump stops with brackets. Excellent shape. $65 plus $10.70 SOLD
shipping.
4x4 rear bump stops with brackets. Excellent shape. $65 plus $10.70 shipping. SOLD
4x4 rear shock brackets. $65 plus $10.70 shipping. SOLD
Leaf spring lower caps. $45 plus $5 shipping.
Thanks, Sharpie
sharpie1972 is offline   Reply With Quote
Old 10-31-2010, 01:57 PM   #2
sharpie1972
Re: Spring hangers. 4x4 and 2wd. Rubber bump stops.
Old 11-02-2010, 10:59 PM   #3
sharpie1972
Old 11-03-2010, 06:50 AM   #4
72k5zl1
72k5zl1's Avatar
did you get my 4x4 front one out yet? thanks, glen
72k5zl1 is online now   Reply With Quote
Old 11-03-2010, 07:56 AM   #5
sharpie1972
Hi Glen, on the way USPS Priority Mail. You should be seeing it anyday. Thanks, Sharpie
Old 11-03-2010, 10:37 AM   #6
fine69
fine69's Avatar
PM sent. I need all 4 rear spring 4 x 4 hangers with shackle.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 11-03-2010, 10:44 AM   #7
pound41
I need 1 rear shackle flip and a good set of bolts for the front and rear springs.
pound41 is offline   Reply With Quote
Old 11-03-2010, 10:47 AM   #8
sharpie1972
fine69 PM sent.
pound41: 4x4 shackle? They are slightly different than 2wd. I have a 4x4 frame coming in soon that I can pull one from. Thanks, Sharpie
Old 11-03-2010, 11:07 AM   #9
pound41
Sorry Sharpie trying to do 2 things at the same time. I need the rear shackle for a 71 4X4 blazer and the bolts if you have them. Blazer has a mild lift and a broken rear leaf. I have a stock set to replace it with. I have put new bushing in the springs. One shackle was missing I want to change the bushings so when I go to change the springs I can do both sides quickly. The bolts threads are rusty on the front and rear so I would like to change them out.
Old 11-03-2010, 11:09 AM   #10
sharpie1972
Gotcha. I'll let you know how things look when I get the frame in (it's from a 72 4x4 blazer). Should be here in the next week. Thanks, Sharpie
Old 11-08-2010, 09:12 AM   #11
sharpie1972
Got a shackle for you, Just working on getting the bolt out! Sharpie
Old 11-15-2010, 10:27 PM   #12
sharpie1972
Old 11-16-2010, 06:53 AM   #13
neo1370
I'm interested in the 2-wheel front hangers if you have another pair.
neo1370 is offline   Reply With Quote
Old 11-16-2010, 03:26 PM   #14
sharpie1972
I'll split this set. $50 plus $14.50 flat rate shipping for the front two. Thanks, Sharpie
Old 11-16-2010, 03:54 PM   #15
pound41
Sharpie any luck with my shackle and bolts for all 4 springs
Old 11-16-2010, 04:11 PM   #16
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Got any exhaust hangers?
D.PASSMORE is offline   Reply With Quote
Old 11-16-2010, 07:49 PM   #17
neo1370
I'll pass,just thought you might have another pair. Don't want you to have to split a set up
Old 01-17-2011, 12:36 PM   #18
blap
blap's Avatar
Hi, Have any more rear 4x4 leaf spring hangers? I need all 4
Also if you still have the rear shock mounts i need both sides
Thanks.Brad
blap is offline   Reply With Quote
Old 01-17-2011, 01:24 PM   #19
sharpie1972
Hi Brad, I have a 72 K5 frame coming in soon. I'll let you know how the spring hangers look. Sharpie
Old 01-17-2011, 07:06 PM   #20
blap
blap's Avatar
Old 01-17-2011, 07:22 PM   #21
sharpie1972
Still have them PM sent. Thanks, Sharpie
Old 01-17-2011, 07:34 PM   #22
sharpie1972
Shock mount pics.
Old 01-24-2011, 11:01 PM   #23
blap
blap's Avatar
Here is the 4x4 frame I have
Old 01-24-2011, 11:09 PM   #24
sharpie1972
Yep, those are the ones I have for you. Thanks, Sharpie
Old 01-25-2011, 12:08 AM   #25
Maxxd07
Maxxd07's Avatar
Hey sharpie would you have a 4x4 1/2 ton 3 leaf front spring in decent shape lying around?
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
