Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 10-31-2010, 07:31 PM   #1
60apache
60apache's Avatar
60-62 complete power brake set up disc
this will include one of captainfabs brackets a master cylinder and booster from a 80 model c10 and a prop valve from cpp for disc/disc. the push rod has already been modified soit is ready to be bolted up. I used this setup for about a month then put on the kit from cpp stupid me because this setup I had worked better. but I am not changing it out again. 165.00 shipped
60apache is offline   Reply With Quote
Old 10-31-2010, 10:23 PM   #2
Captainfab
60-66 Nut
Re: 60-62 complete power brake set up disc
Were you having issues with the operation of this setup?
Old 11-01-2010, 08:18 PM   #3
60apache
60apache's Avatar
at first the pedal was going to the floor but still stopped good. I ordered the cpp kit then realized I needed to move the pivot point down 1" did that and it worked great, but since I already had the cpp kit sitting here and the booster was smaller and the whole setup looked better I went ahead and put it on. I have to say the setup I had before worked better since I have a large cam and the booster was bigger. well hindsight 20/20 I wish I had not ordered the cpp kit and left it alone.
Old 11-03-2010, 06:15 AM   #4
Greg63
Enjoy your truck
Greg63's Avatar
I am interested in the pushrod, bracket and booster if you decide to split it all up.
Greg
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 11-04-2010, 09:02 AM   #5
rcnutt
rcnutt's Avatar
150 shipped?
rcnutt is offline   Reply With Quote
Old 11-04-2010, 09:03 AM   #6
rcnutt
rcnutt's Avatar
sorry, will this work for my 66?
Old 11-04-2010, 12:11 PM   #7
Captainfab
60-66 Nut
It won't be a direct bolt on. This setup is specific to the '60-'62's. It can be made to work with a couple added holes. The '63-'66's have a different bolt pattern on the firewall.
Old 11-19-2010, 03:25 PM   #8
slepysal
slepysal's Avatar
still have it ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 11-20-2010, 07:59 PM   #9
60apache
60apache's Avatar
sold the booster bracket and mast only thing I have is the prop valve
