Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-31-2010, 09:17 PM   #1
baclay9
What size exhaust should I run
I am going to be running a well built 454 in my truck. I will be running Sanderson headers. They are 1 7/8" primary tubes. I also want to run 40 series flowmasters and am going to dump them just before the rear axle.
What size exhaust system should I be running behind this beast? Should it be 2.5" or 3"? X pipe or H pipe?
Thanks formthe help!!!
baclay9 is offline   Reply With Quote
Old 11-01-2010, 07:11 AM   #2
bigsnookmaster
bigsnookmaster's Avatar
Re: What size exhaust should I run
I'd go 3" with an X.
bigsnookmaster is offline   Reply With Quote
Old 11-01-2010, 01:12 PM   #3
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
2.5" at the most. And dump the flowmasters, they are one of the worse flowing mufflers on the market.
ProStreet68SB is offline   Reply With Quote
Old 11-01-2010, 01:17 PM   #4
baclay9
What muffler would you reccomend? I really like the way flows sound.
Old 11-01-2010, 01:44 PM   #5
Alex Hayley
I like my 3" with an x dumping behind the rear wheels. I went with Borla XR-1 Sportsman 3" in/out which I really like.
http://www.borla.com/products/produc...?cat=2&type=72
When looking at mufflers, I noticed that Flowmasters are baffled and have a number of 90 degree turns within them. The Magnaflows are not baffled BUT reduce to 2.5" even if the inlet and outlet size is 3". The Borla is 3" all the way through. All of the previous information is what I noticed as I looked at mufflers and could be incorrect based on the exact muffler I looked at.
Alex Hayley is offline   Reply With Quote
Old 11-01-2010, 01:51 PM   #6
Super73
Super73's Avatar
The hooker Aerochamber sounds very good IMO and crushes the blow master.
I recently switched from a 3" x pipe that had warlock muffles which had electric cut outs hung on them, to, dual electrich cut outs right off the collector knecking down to 2.5" and in to dual 2.5" turbo mufflers. To tell you the truth, for driving around, I could not be happier. Picks up 20rwhp on the dyno when the headers are open. So I get the best of both worlds, quiet or mean..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 11-01-2010, 02:16 PM   #7
bradh
Someone posted this in another thread and I bookmarked it. Really good article. I'll be reading it again before I do another exhaust.
http://www.pontiacstreetperformance....p/exhaust.html
bradh is offline   Reply With Quote
Old 11-01-2010, 03:05 PM   #8
baclay9
Anybody heard anything about spintechs. I have been reading good things today and some of the clips on youtube are mean sounding. This is a link to the muffler.
http://www.spintechmufflers.com/muff...gr0qc4vdrdvtp4
Here is a link to a 454 with these mufflers behind it.
Sounds pretty darn mean to me.
Old 11-01-2010, 05:31 PM   #9
baclay9
After looking around I may go with the Spintech Pro Street mufflers. I am thinking 2.5" exhaust with an H pipe.
Old 11-01-2010, 06:05 PM   #10
nomrlz
nomrlz's Avatar
i wanted spintechs when i did my wagon but they were gonna take too long to get. i ended up with magnaflows and am happy with them. still like the spintechs prostreets tho.
nomrlz is offline   Reply With Quote
Old 11-01-2010, 06:16 PM   #11
ProStreet68SB
that would be a great idea! very good choice of everything there.
Old 11-01-2010, 07:42 PM   #12
RatPwrd72
RatPwrd72's Avatar
x4 on the 2.5" pipe, it'll make more torque than the 3" and keep the sound to a minimum. It takes alot of motor to justify 3" pipe.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
Old 11-01-2010, 09:12 PM   #13
tonypaul
tonypaul's Avatar
This came up in my search-
http://67-72chevytrucks.com/vboard/s...d.php?t=263014
I recently went through this same process on my BMW 850I (V12) when I wanted to replace the exhaust system. I tried 4 different mufflers, I ended up with the Borla's. For some strange reason I liked the sound of the flowmasters on the BMW at idle but the Borlas had better power through the powerband of the engine.
But as of now I have a 3" x pipe with Flowmasters waiting to go on the truck Im building now..... But its only because what I had laying around. Im sure I will be changing out the mufflers in the very near future....
tonypaul is offline   Reply With Quote
Old 11-01-2010, 10:18 PM   #14
shortbed70
shortbed70's Avatar
I have spintek's on my 65 but cant really get a good video in the garage of it running. They are the prostreet type and man they sound racey!!! BBC go 3"
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 11-01-2010, 10:30 PM   #15
baclay9
Can yu keep them somewhat quiet if you are trying? Like say taking off from a stoplight with a cop sitting beside you? Are they just really loud when you punch it? How is the in cab noise? Can you listen to the radio ect...
Old 11-02-2010, 01:06 AM   #16
Super73
Super73's Avatar
Why do you say this, because I have to disagree about the making more TQ.. I can show you countless dynos featuring different vehicles and exhaust designs where an open headered dual cut out design makes more power. Many of the ones I can show you show the same HP/TQ from aprox 2,500ish rpm to aprox 4,000rpm, then from there it's all win for the open system. I have never seen 1 case personally where this has shown to loose low end. I think it all comes down to proper design and scavaging.
I have tested this personally with:
My Old Camaro SS:
Long tube headers
Dual 3" electric cut outs off the headers
Knecking down to dual 2.5"
Flow Master Y collector dual 2.5" to single 3"
Single 3" in hooker Aero chamber with dual 2.5" out
Buddies 2002 Camaro SS with something similar to mine mentioned above
My truck with a couple different set ups:
347ci motor
3" X-pipe off the headers
Dual 3" warlock mufflers corked and uncorked
418ci motor
Dual electric cut outs right off the headers
Knecks down to 2.5" in to turbo mufflers
Several other cars I have dynotuned for others with various cut out set ups.
Old 11-02-2010, 08:46 AM   #17
baclay9
Looks like a pretty even split between 2.5" and 3" pipe. Is this like a edelbrock vs. Holley argument?
Old 11-02-2010, 09:07 AM   #18
nomrlz
nomrlz's Avatar
i can tell you. if you drive the car a lot. the loud/racey mufflers will get annoying after awhile. the drone will just drive you nutz
Old 11-02-2010, 09:36 AM   #19
baclay9
This truck is just being built as a toy, weekend cruiser type vehicle. Not my daily driver by a long shot.
Old 11-02-2010, 09:39 AM   #20
Alex Hayley
Smaller exhaust producing more torque is a very generalised statement that can be correct if the motor is small enough. If the motor is big enough and flows well enough, a step up to 3" may be necessary. With a 454 that is quite modified, I cannot imagine that a 3" would be too big. Why don't you post the specs (heads, cam, compression, carb, etc). That would result in recommendations based on the engine.
Old 11-02-2010, 10:18 AM   #21
nomrlz
nomrlz's Avatar
Here's a muffler flow comparison chart. The formula for required exhaust flow is: horsepower times 2.2.
Muffler flow in CFM
OEM............................................... ...................... ...........225
Gibson SuperFlow 788200............................................ ..311
TTS Bullet Cat Converter......................................... ........324
Flowmaster 40 series 42540..........................................352
Flowmaster 50 Series............................................ .........362
Flowmaster 40 series 43040..........................................392
Dynomax Super Turbo............................................. .......410
Flowmaster 62631............................................. .............435
Carsound Cat Converter......................................... ........436
FLP Cat Converter......................................... ..................440
Edelbrock Victor 5535.............................................. ........562
Flowmaster 40 series 435409..........................................57 6
Edelbrock RPM series 5511.............................................. 579
Flowmaster Delta Force Racing 54040-10........................634
Edelbrock 304 series 5560.............................................. .640
Edelbrock Gen App 5505.............................................. ....708
Dynomax Race Magnum Welded 17216...........................711
Borla XR-1 40600............................................. ................836
Borla XR-1 40615............................................. ................854
Dynomax UltraFlow SS 17263..........................................100 0
Dynomax Race Magnum Welded 17218...........................1000
Borla XR-1 40575............................................. ................1100
Dynomax UltraFlow......................................... .................1133
Edelbrock Victor 5537.............................................. ........1400
Borla XR-1 40450............................................. ................1400
Borla XR-1 40741............................................. ................1450
Dynomax UltraFlow SS 17296, 17268..............................2200
Dynomax Race Magnum Welded 17220, 17224...............2200
Dynomax Race Magnum Welded 17225...........................2600
Old 11-02-2010, 11:22 AM   #22
baclay9
454 bored .060 (468)
Speed pro pistons .210 dome
781 casting heads
(Considering going to 2.19/1.88 valves but haven't decided if it is worth the money yet.)
fully balanced steel crank
Comp Cams XE274H Cam
Edelbrock air gap intake
750 Holley w/vac secondaries
Sanderson 3/4 Length headers 1 7/8 primary
The heads are at the machine shop right now. He is going to cc them for me. If they are 119 cc as I suspect I should be right @ 9.5:1 compression
I also have a set of Speed Pro Pistons that are .340 dome and would put the compression @ 10.2:1. I know that would be iffy on 91 octane though and really don't want to take the chance. I figure 9.5:1 make plenty of power.
Old 11-02-2010, 01:27 PM   #23
shortbed70
shortbed70's Avatar
I really don't know cause I haven't drove my truck in almost two years. I would think they shouldn't be any louder than a short glasspack at mild throttle but get into it and they sound like open headers without the popping. They have several kinds I got the loud ones they have some that are quieter and louder.
Troy
Big Red Dog build
Old 11-12-2010, 01:27 PM   #24
baclay9
781 casting heads
Wanted to bump this with my engine specs one last time for last minute opinions. I am ordering mufflers soon. I talked to the guy at the muffler shop and he acted like I was crazy for even considering 3".
Old 11-12-2010, 01:37 PM   #25
Alex Hayley
Unless the guy at the muffler shop has alot of experience with high output engines, I would ignore his opinion and look to the guy who is working on your heads and your engine.
How big are the intake runners in your heads? I don't know chevy big blocks very well.
If you just want to make a quick decision, I don't think you would be crazy going with 3" but it might not be very necessary though.
