camaro subframe question
Can I use the camaro subframe on my 57 1 ton frame??
Re: camaro subframe question
Do not see why it would not work. The width is the same as the 1/2 tons I would venture.
Yes-I did one on my Brother's 57.....great ride.
Don |
I'd have to look in the assembly manual, but I think the 1 ton frames are deeper than the 1/2 ton. I do know they have thicker steel.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Your brothers 57 was a 1 ton too??
even if its deeper or thicker steel, you could still adapt to the differences and graft it on in the same fashion. I just did a 3/4 ton. Im not sure where they lie between the 1/2 tons and the 1 tons. It went very smoothly. no issues.
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
Thanks nikwho, that is a great build thread you got going. Pictures are worth a thousand words. What is the height of your 3/4 frame rail top to bottom?
