Old 01-13-2002, 11:36 AM   #1
dave's70
Post 77 chev hp?
Does anyone know what or where I can find out the original stock hp of the 1977 chevy 3/4 ton trucks with the 350?
70 C-10 350 with weind intake,eldelbrock carb,HEI,305 heads,a mild cam. also a blazer tank w/bed fill,shaved stake pockets and tailgate
dave's70 is offline   Reply With Quote
Old 01-13-2002, 08:02 PM   #2
Chevyman69
Vortec 350's Suck
Post
I assume its a 4 bbl, which means its 165hp@3800 rpm
260 lb ft torque@2400 rpm
69 CST 10, 402, steel crank, heavy rods, Federal Mogul Forged Pistons, 9.9:1 compression, polished ported 781 heads 2.19/1.88 manley stainless valves, Crane Powermax Hydraulic roller 288/296 and .587,.610 lift, hardened pushrods, Crane Roller Rockers, Weiand Action Plus, 750CFM Rochester QJET, MSD HEI, MSD 8MM Wires, Dynomax Ceramic coated headers, should be about 500 H.P. 700R4 2500 stall, pretty nasty shift kit, 373 Auburn Pro Series Posi, buckets/console air/tilt/tach 4wheel discs
Daily Driver: 92 Chev Reg Cab LWB Silverado 4x4, loaded, 350 Accel filter/cap/rotor/coil/MSD wires/AC Delco RapidFire plugs, Edelbrock intake and headers, 180 degree thermostat, Hypertech Thermomaster Chip, true duals 700R4 with B@M Shift Kit for now!
69 Chev CST 10 reg cab lwb
Daily Driver: 92 Chev Reg Cab LWB Silverado 4x4, K.I.A 7:51 AM 04/22/03
Will be resurrected
Chevyman69 is offline   Reply With Quote
