PROJECT 7DEUCE
![]() Join Date: Dec 2002
block ???
Can anyone help me with these stamping's??????I can't see the cast ## on the back of the block????EA2209
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Cantankerous Geezer
If it's a V8, go to Mortec.com. If it's a six, go to inliners.org
Fred There is no such thing as too much cam...just not enough engine. ![]() |
67-72 Addict!
Frenchblue72, clean the block real good and take kids play-do and press it down evenly over the casting. Slowly peel it up and you will see the impression of the numbers (reversed image). You may have to do this a few times to get a good impression. Works like a charm!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
