Old 11-01-2010, 01:11 PM   #1
3r!c84
Badass
3r!c84's Avatar
Starter and alternator wiring
On the starter there is 1 big conector and 2 small ones. What small one do I put the wire? Or do it matter?
And the alternator plug can go in both ways what is the right way to plug it in?
Stock wiring for a 84 c10 305 th350
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-01-2010, 02:03 PM   #2
danomano
Re: Starter and alternator wiring
One should be marked R and S.
S is for start and the R is for the ignition(you only need this if you got the old points system don not use on HEI).
We need to see what type of alternaot you got.
danomano is offline   Reply With Quote
Old 11-01-2010, 02:08 PM   #3
3r!c84
Badass
3r!c84's Avatar
so put it on the R one? is that the one closet to the block?
and its just a stock alturnator with 3 connocters. one plug type and one bolt in wire
guess they call it a 3 wire ?
-00 Saturn 5spd
1/4:13:90
Old 11-01-2010, 03:00 PM   #4
fixit-p
fixit-p's Avatar
Connect the starter wire to the "S" terminal it's the one closer to the block.
The alt should be a 12SI and the terminals should be labeled 1 and 2 # 1 should have switched ignition through a charge light or resistor and terminal 2 should have full battery power.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
