Old 11-01-2010, 05:02 PM   #1
Triple6Goat
Triple6Goat's Avatar
what oil to use in my L6 and 3spd.
Im about to do a much needed oil change and want to make sure I put the correct oil in my truck. Also im about to drain the 3spd. trans and refill it. Do I use 10w-30 for the engine and 80w-90 for the 3spd.? I searched and couldnt find a thing.
1984 C10 swb
1985 K20 longbed 4spd
1977 K10 longbed -SOLD
1962 Chevrolet C10 swb 6cyl. 3spd. -SOLD
Triple6Goat is offline   Reply With Quote
Old 11-01-2010, 06:03 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: what oil to use in my L6 and 3spd.
I think you are safe with your choices.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 11-01-2010, 09:54 PM   #3
62gmc910
62gmc910's Avatar
You would be best to use a diesel oil CI -4 10w30 if you can find it , oil for modern gas engines doesn't have enough Zinc in it to lube the flat tappets (cam followers/lifters) http://www.bobistheoilguy.com/forums/ubbthreads.php
look around in this link for a deeper explanation
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 11-02-2010, 11:49 AM   #4
Triple6Goat
Thanks for the help guys, I appreciate it.
1984 C10 swb
Old 11-02-2010, 06:06 PM   #5
Shaky
Six in a row makes it go...
Shaky's Avatar
A little more discussion about engine oil:
http://67-72chevytrucks.com/vboard/s...d.php?t=427875
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 11-04-2010, 02:53 PM   #6
Triple6Goat
Good link, I think im gonna use 15w40 rotella oil. I just hope Orielly's gave me the correct oil filter.
1984 C10 swb
Old 11-04-2010, 09:49 PM   #7
66coffin
66coffin's Avatar
what do you guys think of that Lucas oil additive? Any good for the same application as triple6goat?
'66 c10ish straight 292 power!
66coffin is offline   Reply With Quote
Old 11-05-2010, 02:17 PM   #8
bama63
bama63's Avatar
Lucas oil additive is really great stuff i use it in everything i own including my lawn mower
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 11-05-2010, 02:57 PM   #9
62gmc910
62gmc910's Avatar
We use wix 51060 anti drainback ,replaces long chev spin on , keeps the filter full instead of 1/2full at start up
As to the lucas , I don't know , the zinc additive is what is missing in new "gas" engine oil, they mostly have roller lifters
Rotella t or its equivalent is cheapest , wallmart supertech owneroperator oil has had good reports
