Carrier bearing dust shield
Are the dust shields for the carrier bearings supposed to be welded or attached some way to the drive shaft? Mine spins on the drive shaft and makes some horrible noise around 50 MPH.
Re: Carrier bearing dust shield
Those sheilds were press on the shaft, & do come loose ,as they are a stamped pc. The DL shop that did my shaft didnt use the sheild, & told me that "I dont use em because they come loose". Now I am sure you will hear differering opinions on this (I have). The next shop that got my shaft for a shorten & balance told me that wasnt right? My reply was that I dont run in the rain or nasty weather, & only see 2000 mi per yr (on a good yr ) with that old truck. I tend to agree with the 1st guy....he!! I can tear it down, & replace that bearing every 3 or 4 yrs, & I dont need to hear that sheild spinning on the shaft
http://community.webshots.com/user/hotrodhorn |
18 Till I Die
If you do pavment only then I would leave them out...Mine also does not see rain and I left them out.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
I don't drive in the rain, so I think I will just take the cover off...Thanks for the replies.
the boat guy
if it's less work to spot weld the shield on I'd do that. We always take the dust sields off of all of or driveshafts. All they do is hold the dirt in or come loose.
remember to get the front driveshaft, bolt on yoke and rear driveshaft lined uup the way they were ballanced or you could get a nasty vibration.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
