![]() Join Date: Jul 2009
Division bar felt replacement
How do the replacement division bar felt get attatched. Are they glued in?
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
Re: Division bar felt replacement
Rivets,and setting tool.
ok thanks
I am a Referee of life.
I used a pop rivet gun.The tip wouldn't fit into the channel so i used a short piece of tubing in 1/8 (I think) to extend it.I just put the tube over the rivet rod and pushed it in
the tool.then it reached into the channel easily.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
The felt comes with an adhesive back. You strip the center, set it in place and then do the two sides. Super easy. My 9 year old son helped me . It goes easier with a second set of hands
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
Where did you guys order from
I bought mine from the truckandcarshop.com. I think it was like 10.00 + shipping. They worked great.
![]() Join Date: Oct 2001
I've always took a wide flat screwdriver and dragged it through the channel and cleaned out the channel w a wire brush after that then run a bead of Black 3M glue down the channel and place the new channel strip in the cleaned area! good luck.......
Things happen for a reason! |
Cool thanks guys. I just glass beaded everything and painted it up with black paint. so that is the last thing i need to complete the rebuild
I bought mine at Classic Parts, I bough a decent rivet gun and ground the sides of each side of the barrel so it would fit inside the track, it changed the barrel from round to rectangular and it still works just as it did before but it fits perfect in the division bar felt.
