Old 11-01-2010, 09:56 PM   #1
tim21391
tim21391's Avatar
bed bolts
i took my bed apart and broke all the bolts off and was wondering is there a place to look at for sizes of bolts i need and what not..kinda a dumb question
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 11-01-2010, 10:28 PM   #2
Tommy454
Tommy454's Avatar
Re: bed bolts
LMC has a kit for the bed bolts, can't get much easier than that.
http://www.lmctruck.com/
Tommy454 is offline   Reply With Quote
Old 11-02-2010, 12:04 AM   #3
greenbd71
greenbd71's Avatar
Re: bed bolts
If you have a local Ace Hardware Store I would give it a try....anytime I need some kind of bolt or nut for my truck they had them.
greenbd71 is offline   Reply With Quote
Old 11-02-2010, 01:48 AM   #4
tim21391
tim21391's Avatar
Re: bed bolts
thats what i was plannin on doing. lmc bolt kit is kinda pricey so i figured a bolt is a bolt and you can get them cheaper at a hardware store instead of paying like $2 a bolt at lmc i found you can get a bolt for like less then a doller at the hardware store
Old 11-02-2010, 07:35 AM   #5
stich626
Re: bed bolts
count up your bolts..
the kit is 29 bucks..
at a buck a bolt at hardware store( don't forget the washers and nut is extra)
you have only 29 bolts..
I'll bet the kit is cheaper than the local hardware store..
the S/S is 59.00
have u priced bolts/washers/lock washers(if used)and nuts
non graded junk you might get at 1.29 a set (bolt/washer(s)/nuts) MIGHT..
good luck..
stich626 is offline   Reply With Quote
Old 11-02-2010, 08:30 AM   #6
cdowns
cdowns's Avatar
Re: bed bolts
local purchase no wait no shipping costs which people dont include in there "bargin" prices they quote from LMC
no need for "graded" bolts as there is no load to speak of in an assembled bed
for better grade tho look at a boat supply place
my local fastener company has galzanized for less than50cents each stainless less than a dollar
Old 11-02-2010, 12:11 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: bed bolts
Try your local Tractor Supply Company or Fastenal store, probably be cheaper than most hardware stores.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-02-2010, 12:56 PM   #8
gkesseru
gkesseru's Avatar
Re: bed bolts
The large washers with the offset square hole is not available in hardware stores. These are the ones that hold the bed down.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
