Old 11-02-2010, 12:00 AM   #1
a.c.1
Please, someone help i.d. these spindles
A buddy gave me these spindles to help upgrade drums to disc on my '68 c10shortwide. He said they came off an '86 1/2 ton. I started doing some measuring and not sure if or how this would work. The disc spindle measures at about and inch taller than my original drum spindle. The rotors that came off of them are 5 lug and 1 1/4" thick. The spindels themselves measure out similar 1 1/4" x 4 1/2 on the drum and 1 1/4" x 4 3/8"
Can anybody i.d these spindles or know if they will work on my '68. If so what will need to be done about the spring. I got the springs that came off this truck, they are the same height but are a little thicker.
a.c.1 is offline   Reply With Quote
Old 11-02-2010, 12:17 AM   #2
a.c.1
Re: Please, someone help i.d. these spindles
Old 11-02-2010, 08:51 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
You will need different balljoints and outer tierod ends.
I suggest using aftermarket spindles or drop spindles, for the year of your truck.
Many of the board vendors sell them.
Search "drum to disc" conversion.
This question gets asked almost daily.
Keith
Convert to disc brakes.
Old 11-02-2010, 08:52 PM   #4
lolife99
lolife99's Avatar
The '86 spings will work fine.
Keith
Old 11-02-2010, 09:13 PM   #5
a.c.1
Thanks for the help. So I'm assuming the ball joints will make up for the taller spindle? I'm just trying to avoid a loose fitting spring.
Old 11-02-2010, 09:20 PM   #6
lolife99
lolife99's Avatar
Don't worry about the spring being loose,... it won't be.
This is a very common swap.
Keith
