Old 11-02-2010, 05:16 PM   #1
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Question 4x4 newbie needs help on ID plz
Okay I have a 1967 Chevy Suburban with a BoP TH 400 tranny and the transferr case has a silver tag on it.
My guess is a 205 or NP 205.
Here is what it has on it:
71 41 CTC
9 13 71 205
Let me know what I have please.
Thanks folks!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 11-02-2010, 08:14 PM   #2
85burb
85burb's Avatar
Re: 4x4 newbie needs help on ID plz
I would guess it is a 205.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 11-02-2010, 09:01 PM   #3
C20-67_N_MO
What does the NP suppose to mean on these things?
Anyone know that much?
Old 11-02-2010, 10:52 PM   #4
Davidmichael
Davidmichael's Avatar
NP= New Process, as in the company that manufactured these transfer cases- New Process Gear.
Take a picture of it, or even just the case itself. It should read like the following:
model X XXX ratio xxx
serial x x xx
Assem. no xxxxxxxxx
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 11-03-2010, 06:27 AM   #5
C20-67_N_MO
serial x x xx
Assem. no xxxxxxxxx
Cool. Thanks!
Still in the process of cleaning her up.
on the heavy part of the case is has C-99404 and on a very small tag has 7-20-71, which I am guessing is when it was made.
More later once I get that heavy thing cleaned up.
Thanks guys for all your help.
Old 11-03-2010, 09:36 AM   #6
Davidmichael
I know C-99404 is stamped into the cases, but do not know exactly what it means.
01 S10 ZR2
Old 11-03-2010, 07:38 PM   #7
C20-67_N_MO
Want to put in new gaskets and seals while it is apart, how easy is this?
Old 11-04-2010, 08:39 AM   #8
Davidmichael
I have never done it, from what I can see, it's pretty straight forward. Check the gear oil when you drain it for metal shavings, check all the gears, and then replace anything that needs replaced including the seals. Fill it back up with the proper oil. I always use stuff from royal purple (big $ but worth it IMO)
01 S10 ZR2
Old 11-04-2010, 12:55 PM   #9
C20-67_N_MO
Good advise - Thanks man.
Old 11-08-2010, 08:03 PM   #10
swamp rat
swamp rat's Avatar
Do yoursepf a favor and use the search feature here for NP 205 and or Transfer case, its been coverd a bunch of times and good info posted.
Also do a google search, both Web and Images for NP 205 and NP 205 rebuild kits.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-09-2010, 04:14 AM   #11
C20-67_N_MO
Only thing I came up with is from Monster Transmission and just the gasket set is $70!
Rebuild is something like in the mid $200 or so which seems fair.
Might as well just have my tranny guy go thru it and make sure it's okay before proceeding.
Old 11-09-2010, 04:31 AM   #12
swamp rat
swamp rat's Avatar
I suggested google images so you can see pictures of the NP205 and make sure thats what you have, the NP203 looks a bit different.
Parts can be a bit expensive, you can allways start with a napa store too. but heres another link.
http://quad4x4.com/New_Process_NP205_Parts.html
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-09-2010, 01:13 PM   #13
Redcap
Those prices are absolutely ridiculous. Much better price at the link below.
http://www.northwestfab.com/rebuild.html
OP, in your identification, look between the rear output and the front shaft's rear bearing retainer. If there is a little 3-bolt cover between them, it is a 205. If not, it is a boat anchor.
Redcap is offline   Reply With Quote
Old 11-09-2010, 05:39 PM   #14
C20-67_N_MO
Now your talking!!
Thanks guys!
Old 11-09-2010, 08:02 PM   #15
Rede
I had my NP208 rebuilt at a local shop in April.
New seals, bearings and chain. And of corse labour.
900 beans later.
Reman case is 1200 + tax. (after core return)
When I blew the 4spd in my truck I drained the tcase fluid for removal and it looked like pink metal flake paint.
Chalk full of partical goodness. /sigh
Rede is offline   Reply With Quote
Old 11-09-2010, 08:51 PM   #16
C20-67_N_MO
Ouch!
Old 11-09-2010, 10:11 PM   #17
swamp rat
swamp rat's Avatar
Thanks for posting Redcap!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-09-2010, 11:15 PM   #18
Rede
Ouch!
Tell me about it. lol
